XS Power
Just so you guys know where I got that an xp3000 would be good for 3000 watts was in page 6 of the group buy thread where scottie posted this:
"Choosing which XP series battery to use is made fast and easy by referring to the part number. The model number is the wattage recommendation, so for example, if you have a 750W system, you should add the XP750 to your existing charging system. If you have a 2,000W system, choose the XP2000. If you are building a massive ground pounder with 30kW, you need 10 x XP3000's. If you want to add more capacity so it can play for extended periods of time, then add more as needed to create the desired capacity. It never hurts to have more capacity than needed... the more battery power you have, the higher your voltage will stay under load, and the louder your system will play."
http://www.stevemeadedesigns.com/board/topic/132241-xs-poweraudio-savings-smd-group-buy-2012/page__st__100
Edited by youngsticky
http://www.stevemead...2/page__st__100
yeah i dont understand how they get these numbers. ive read that the d3100 is good for 5000 watt systems. but to run a 7k daily driver id need 4 d3100 and 2700 up front.
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
We get the numbers by doing tests on the batteries. There is no reason a person would need 4 D3100 and a D2700 up front for a 7k watt daily driver. You would need at least 2 D3100 for 7k, because I am pretty sure the system would not have enough alternator power to keep up with 7k watts.
  • Who's Online   0 Members, 0 Anonymous, 1119 Guests (See full list)
