So I reinstalled my amp yesterday and for some reason it's not working now. My amp turns on and stuff so it can't be ground/12v are fine.
I checked it with a dmm and there was no output in the speaker inputs. So the problem has to be with either rca's or headunit.
My headunit is Alpine CDA-105 and has no on/off for subwoofer output. It's always on, so that's not the problem. And my RCA are new. I'm lost....
Anything else I can check for?
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Check the RCAs with a DMM. Set it to AC volts, put the + probe on the pin in the middle, the - probe on the outside and turn it up.
Oh, I haven't tried this yet! I will do this for sure when I get home!
(1) Mechman 240
TEAM NWSPL
155db outlaw
Anything else I can try besides that?
(1) Mechman 240
TEAM NWSPL
155db outlaw
settings correct on the head unit ... maybe the balance / fader may have turned somehow ...
:diablo: cold solder can be in the way of the speakeroutputs.
"in the abundance of water, the fool is thirsty" Bob Marley
That head unit also has a subwoofer on/off function. Perhaps you accidentally turned it off?
Misread :)
Edited by TheNewbie
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
