free box designs with a sketchup pic or file
teardrop
Kewwood w3013ps X2
vas(liter) 83.7
fs(hz)( 25
qts .82
xmax (MM) 15.1
tuned to 33 is fine or 35 i just need to bring up the low end and dont want a one note wonder.
Looking for a slot port for a 87 accord hatchback
Not sure if subs should fire up or rear but current sealed box is loudest fire-ing rear
max width 34"
max height 15"
Kewwood w3013ps X2
vas(liter) 83.7
fs(hz)( 25
qts .82
xmax (MM) 15.1
max width 34"
max height 15"
I guess I'll drop in, not the best, but I can help with these requests. I'll get this one. Since no depth was stated, 22.5" is the set depth.
Tuned to 33.73hz
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
How much power are you giving the sub?
Around 2k unclipped
2010 F150 FX4
-18" AA Mayhem
-Crescendo BC3500d
-Pioneer GM-D9500F 4-channel
-2 Crescendo FT1
-2 Crescendo Neo Forte 6.5
-Pioneer AVH-P3300BT
-6000K HID Headlights/Fog lights
-All LED interior lighting
-20% tint on front windows, 1% rear windows, 5% windshield strip
-Big3 (XSFlex 0ga)
-DC Power 270XP
-Group 65 NorthStar AGM battery
Coming soon/plans:
-Build log
-Blacked out mirror reflectors
-Tinted tails/3rd brake light
here ya go sid
How big is that port area? Looks small
Can you give me the specs of the box.
can you design me one for 2 DC LVL 3 15s
max dims
42" wide x 25" deep height doesn't matter
sub up/port back
tuned to 32hz
Thanks a mill
Getting loud is only half the job;sounding good while doing it is where the glory is.1998 Jeep CherokeeHead Unit: Pioneer AVH-P6300BTFront Stage: Kenwood 6.5Rear Stage: kenwood 6.5Tweeters: SoundstreamMids/Highs amp: Hifonics Zeus 600.4Sub Amp: Hifonics BRZ2400Subs: 4 Skar VVX 10s(only running 2 now; still has all of them though)Batteries: Optima Red Top(under the hood)XS Power D1200(in the trunk)0 AWG Power Wire
max dims
sub up/port back
tuned to 32hz
Thanks a mill
Overpowering them or underpowering them?
max dims
sub up/port back
tuned to 32hz
Thanks a mill
I'll be putting a bit over 1000w on each and they are rated at 900w
Okay, Guess I'll make it a little less than 6 cubes. I'll have your design done in less than an hour.
(2) SA-10s
1 AQ 2200D at either 1 ohm or .5 ohms so 1100 watts per sub before rise
33hzz tuning
pontiac g6 sedan trunk
max specs
height 15
width 30
depth 18
slot port
think i got it all
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
max dims
sub up/port back
tuned to 32hz
Thanks a mill
Okay I have yours done. I was too lazy to label it. It's has an 1 baffle
It's 20.75h x 40w x 23d
Port is 18.5h x 5.25w x 30d (Actual inside port length is 24" long)
Tuned to 32.60hz, If you want the layout sheet, you'll have to pm me.
