free box designs with a sketchup pic or file
teardrop
dying to do a sketchup right now... lol if you give me the box specs i'll draw it
lol if thats the case pm me and we can get started on another box! :twirl: and lets see what OP can do here... 2003 ext trailblazer 2 18" dc xls sundown 3k 46w x 38d x as high as you want.. looking for a box kinda like meade's with an interchangeable port...
wher do you perfer subs and port whats the displacment of subs
Subs up port back
whats the sub displacement
.4 total...
wow now this just shows that smd isnt just any forum. We are a brother hood.
here let me put it in retard-onix for u aareehhhh duuuurrrrr ehhh got it now?
Sweet baby jesus the amount of quoting the quote above the quote in a quote is epic
3 sa 10s with a powerbass 3k
4th order Max dimensions 34w x 16t x 22d
witch way you want port to face?
Forward. Will be sealing off from the trunk.
2 10's Alpine type r's
  • 10" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene rubber surround
  • cast aluminum frame with perimeter venting and radial finned heat sink
  • frequency response: 26-200 Hz
  • power handling: 300-600 watts RMS (300 watts per coil)
  • peak power: 1,800 watts
  • sensitivity: 83 dB
  • top-mount depth: 5-7/8"
  • sealed box volume: 0.5-1.0 cu. ft
  • ported box volume: 0.8-1.5 cu. ft
Max dimensions 34w x 15t x 22d
port firing toward trunk
amp is a boss phanton ph5000D 1800 RMS
So will the 13" inch ports work in the front if the depth is 16.5" or do I have to keep the ports away from the back wall? It would give me 3.5" off the back wall or just use an elbow and aim them at the subs? Sorry to bug Ill leave you alone after this one haha!
no they are 6 in ports and need to be more than 6 in from any wall
Sorry I'm still new 2 this stuff. I think this is what u mean.
2cu ft ported factory spec
Overall diameter: 12.626
Overall height: 7.5
Mounting depth: 6.75
Cut out diameter: 11.125
Flange width: 0.75
Flange height: 0.75
no i need to know whats the subs displacment how much air space it takes up in the box
Overall height: 7.5
Flange width: 0.75
Flange height: 0.75
Overall height: 7.5
Flange width: 0.75
Flange height: 0.75
Two Skar Audio vvx 8's Skar Audio sk1500.1 4th order Max dimensions 11.5" height 42" width 16" depth
need sub info
Cutout Diameter : 7-3/8" Mounting Depth : 5.5" Displacement : 0.13 Ft^3 http://www.skaraudio...ucts/vvx-8.html
what way you want subs and port?
I was thinking subs on the sides and port in the middle
here ya go its 1.19 cubes tuned to 33hz with a port area of 10.51
Ok. I found a calculator online. & it came up with
0.05 ft^3
Does this sound right? This is how it calculated this.
Cone diameter: 11.25"
Mounting depth: 6.75"
Xmax: 13.25mm
Magnet diameter: 6.25"
Magnet height: 2.25"
I have one SoundStream SPLX-HF 15". Running on two SoundStream TX1.1300D (one per coil) going to seal off from trunk. I want sub and port facing forward. It is going in a ford contour. Max dimensions are 39w X 31L X 22H Specs on sub are: series wired SPLX-152HF Fs (hz) 35.96 Qms 6.476 Vas (ft³) 87.56 Cms (mm/n) 0.0794 Mms (g) 247.1 Xmax (mm) 13.00 Xmech (mm) 19.50 Piston Diameter (in) 13.19 Sd (in²) 136.6 Qes 0.503 Re (Ω) 2.95 Z (Ω) 4 BL (Gauss) 18.09 Rms Power (watts) 1,250 Qts 0.467 NO (%) 0.78 1w/1m SPL (dB) 90.95 Voice Coil Diameter (in) 3" Impedance (Ω) DVC 2Ω M-vd (ft³) 0.298 Measurements SPLX-152HF Overall Diameter 15.25 Overall Height 9.25 Mounting Depth 8.375 Cutout Diameter 14.125 Motor Diameter 7.875 Motor Height 3.5 Flange Width 0.75 Flange Height 0.625 Weight (lb). 35 I want tuned to 31 hz
i need your displacment of subs
  • Who's Online   0 Members, 0 Anonymous, 1103 Guests (See full list)
