CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
I'm really kidding, can other people see the pic because I can't...
Edited by Noobtastic14
uhoh_45 said:
not a completely good ground, if you are running a system that you don't care about go for it, but a good ground would be frame of the car, drop the ground, drill a hole, or if you have enough run it to the engine block front frame of the car
build coming late April, early May
build log for 1 LVL 5 18" 87%ish done : http://www.stevemead...ab-dc-lvl-5-18/
1997 Dodge Ram 1500 Slt Laramie
Amplifier - AQ3500d.1
Sub - DC LVL 5 18"
Highs - (2x) Selenium ST-350 Super Tweeters 8ohm
Mids - Selenium 6" 200w midrange 6W4P (pair)
Mids/Highs Amp - MB Quart ONX4.125 1000watt 4 ch
Wiring - XP Flex 25' Red, 25' Black
Alternator - Mechman 270amp
Battery - XS power D3100, 1- Yellow top front
more to come...
ill be doing a big 3
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
if you manage to get it under the carpet, or cut the carpet in a way that the lug will be firmly pressed against the metal on both sides of the lug, then it should be fine. my amp grounds are similar to that and i havent had a single issue since i've installed my first amp in my car.
no find a different place to ground it, strip it down to bare metal
AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
what he said, and make sure you sand the paint off of the white under tat bracket so the lug gets a good metal to metal contact
these orphans aren't going to feast on themselves
ill do that and ill post a picture tomorrow
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
Its a decent ground, but for the 2500 you say your running in your sig, I wouldnt use that. At the least I would drill and tap the frame to use for the ground. The best thing I would do is do a neg run back to the front batt. that will help with adding extra batts in the back too.
  • Who's Online   0 Members, 0 Anonymous, 2510 Guests (See full list)
