thanks for all the input guys, and decaf no he didn't.
'93 Firebird Formula V8
H/U- Kenwood eXcelon KDC-X395
Mids/Highs Amp- Hifonics ZXI80.4
Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0
G34 Red Top and a 180amp Ford Alternator
www.youtube.com/TRTC360
Posted (edited)
i would start with an overdrive pulley first. its cheap and "easy" to switch out.
the same engine can be used on a 150mph car as a plow tractor... its about how where you want the output. the stock alt is a tractor, tons of output but slow and tops out fast. HO alt is a corvette, its crazy from 0-60, but let it open wide til over 150mph and it will drop your jaw
Edited by Decaf
Is there a way I can fix my idle output.
Build Under Construction
Head Unit = Kenwood DDX514
Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4
Battery = XS D3400
Wires = Kicker RCA's, 0 Gauge street wire and Stinger
Mids and Highs = Stock
Sub= Kicker L7 12"
Alternator = 220 Mechman
Sound Deadner= Fatmat and Stinger Road Kill
IDK your engine but is it an electronic throttle body or is it a manual (cable driven) throttlebody? If its cable driven almost all engines ive tinkered with have a set screw on them near the butterfly opening to adjust how far open the throttle will remain when you are not depressing the gas pedal. Opening these up enough with your car in drive and getting the right idle speed to keep the alt charging will be your easiest bet.
To do this id recommend getting a buddy to sit in your car holding the brake pedal down while dropping the car into gear while you are under the hood adjusting the set screw. Now if you cant find help heres what you can do. Get a brick and place it in front and in behind of your wheel to act as a wheel chuck and then test your emergency (parking) brake to see that it functions. Once you confirm it works roll down your driver side window as if there is an emergency or accident you can grab the keys and kill the ignition fast, find the set screw on your throttlebody if you have one, turn on your car and let it warm up for about 2 minutes and put it in drive with your parking brake engaged and wheel chucks in place. Now get a volt meter to help you see where your alt starts to charge at 14.4v and open up the screw on the throttle body until it gets the voltage up to that level. Once you have this change gears and put it in reverse (this usually isnt needed but while you are at it, might as well make sure you dont drop engine speed in any other gears but park and neutral) and test it. Once you have it like that ride it around the block and stop dead at a stop sign or red-light and see if your alt stops charging and adjust as needed.
Same EXACT thing just happen with my singer 200 amp! Mike is making me a custom small pully for me :P
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Ive done it on my oldsmobile, my dads envoy and my moms impala and never had any problems. I have heard of people running into problems with it but mainly its the fuel consumption is increased because of it.
Another thing you can do is change the size of your idler pulley if you have one on your engine. Those are super easy to change, just remove the belt, unscrew the bolt and bolt the new one on. Easy as that.
  • Who's Online   0 Members, 0 Anonymous, 585 Guests (See full list)
