Mha Posted March 1, 2012 Report Posted March 1, 2012 I have an avalanche with the midgate removed and the sub box is sealed off. I have my power wires run under the truck. And they go into the bed throw a hole in the bed floor ground. I realy dont have any other option but to put the dc5k on the box or on the floor. I know some do it with no issues and others have had issues. Is ther anything I can do since its my only option. Like put fatmat I have laying around on the box or on back of the amp or add an other baffle to the side im going to mount it? Any ideas. Ps my 4 channel is under the seats all ready.
bighossf150 Posted March 1, 2012 Report Posted March 1, 2012 would this work? http://www.amazon.com/Pack-Vibration-Rubber-isolation-SHIPPING/dp/B001THXRP8/ref=sr_1_4?ie=UTF8&qid=1330628282&sr=8-4 I'm about to start my build and was going to use some until I found a better spot for the amp Used to have a loud truck 2009 Corvette Z06, H/C/I, 150 shot, g force tune, 730rwhp/690rwtq 2013 F-150 limited, MPT Tune, leveled on 35"s
kbsmoker Posted March 1, 2012 Report Posted March 1, 2012 I have my 5k on my box with no problems, but my box is 1.5" thick. I also uses 3 washers under the mounting feet to prop it up, there is an exhaust vent on the bottom of the amp. So if your has no flex it should be fine. I wouldn't use fat mat, I would find some kind of foam padding instead so there is some give. www.dcsoundlab.comyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3 SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator
bigmescan Posted March 1, 2012 Report Posted March 1, 2012 I've used rubber gromitts under the feet of amp and screwed it to the box. SONY XAV-701HDRF power 400.4 RF power 1000bd 3 Sundown x8's d22004 f150 single cab2 sets of components MB quart 6.5 onx (2 tweets 2 6.5 perdoor)stock batt up fronBIG 3http://www.stevemead...-vid-pg-11-922/http://www.youtube.c.../TheBigmescan74
