try to find copper with gold plate
NISSAN SKYLINE GTR R32 (Build in progress)Fosgate POWERhttp://www.stevemead...-fosgate-power/--------------------------------------------------------------------97 Honda AccordRockford Fosgate1400 watts RMS totalhttp://www.stevemead...e-1400watt-rms/---------------------------------------------------------------------
Yeah, they don't have any on the whole site that are copper that i noticed. :( I need at least 20 and the local shop 1 hour away sells them for like 15 dollars each! so I really am stuck. The ones on Darvex are stinger. They have "Bulk" and "crimp" ones, whatever the difference may be they are all brass
Where are you at? A member by me just went and picked up a dozensplod copper lugs for less than $20 at one of the welding suppliers by us.
Eastern canada.. yeah I have seen those copper ones before, actually used them with 4 ga on an old install but I never seen any 0 gauge ones. I would think the 0 ga plod would be tricky to solder. Also, ever hear of any of them corroding? one of the 4 ga i used started to turn green after a few months in the trunk.
I get mine at a local battery wholesale house they're copper with anodized finish 80 cents each..look at a welding wholesale place also..copper is a way better conductor than brass an a lot softer to crimp an easier to solder
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Ok guys, Thank for the input. I'll check around here for some that are insulated/anodized
  • Who's Online   0 Members, 0 Anonymous, 2887 Guests (See full list)
