What're the gross and net cubes of this thing? Curious as the Escape's cargo area looked a little small to me, and I've got an explorer I'm putting hdc3 15's in and around the same tuning, but with a slightly larger box for them I'm guessing.
no way in hell you have a whole cubic foot of bracing in there... even if you do... i'm not sure why you need all that bracing. the most i usually use in a box is .2 cubes.
i guess nothing you can do about it now. GL with your box!
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
I'm actually glad to see this, I usually put .15 in as a little reference point, I put in 1cube for bracing because i thought I mightve messed up somewhere, and only got like 8.3 is my suv heh
You should put port in middle from top to bottom, if you do that change port walls to 2
As cvx mentioned, bracing tends to be under .2cuft unless you have large 45s
try to get 8cuft+, 100sqin will be plenty if that helps
  • Who's Online   0 Members, 0 Anonymous, 1794 Guests (See full list)
