DC Sound Lab
alright so i will post up measurements tonight in the fullest extent.
im going to just keep the back seats down and drill into them for the portion of the base of the wall.
the whole backs of the seats are destroyed anyways so eh, why not!
thanks guys, youll be hearing from me soon
2 DC AUDIO Level 5 18s Carbon Fiber Dust Caps, Direct Leads, Stiffened Spiders
Stinger SPV69, SPV70's (2)
Stetsom 7KD
Excelene 50+ feet 0g Welding Cable
Soundstream 4.500 + JBL 1000.4
Cadence Mids + Earthquake Highs
Clarion 507 BT + EQ
All Stinger Parts/Adapters/ETC.
WHERE ARE ALL THE NEW YORK/LONG ISLAND SHOWS!!!
Box is 7.65 cuft internally tuned to 37 hrtz.
for one 15? holy dick.
There isn't much space back there.
and i know, but i should be good with the seats down.. i hope :/
Stetsom 7KD
Clarion 507 BT + EQ
what power? i say 10 cubes with 12-16 sq in of port tuned to 37
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
runnin a stetsom 7kd at 1 ohm
and i got all my measurements done today.
ill post them in a sec
Stetsom 7KD
Clarion 507 BT + EQ
if i go through the rear doors in the hhr these are my measurements:
for the side pieces of the wall -
28 in. length
24 in. width
32.25 in. of height in the hhr to work with
for the top and bottom and front of the wall -
41 in. length
24 in. width
Now if i go through the cargo area/hatch these are my measurements:
scratch that. for the 18s to fit, i have to fit all wood/pieces for the box through the back doors.
so im hoping someone can help me with that one for the depth of the box itself to maybe taper off a bit smaller back into the cargo area from where the box should begin, which is directly behind the front seats.
i have those very measurements right here:
the height has changed because this part will have to fit through the cargo area, which i will build it in the car, it needs 27 in. of height.
34 in. of depth for the cargo area to be used up
38 in. of length for the cargo area to be used up
thanks again guys :D
Stetsom 7KD
Clarion 507 BT + EQ
and if most of the box can be drawn out to be double baffled i would love you long time.
Stetsom 7KD
Clarion 507 BT + EQ
Help :( i wanna start building my dream
My sketchup recently stopped working for a stupid reason on my laptop also. Even if i uninstall it an reinstall it, its just my crappy laptop.
Stetsom 7KD
Clarion 507 BT + EQ
You dont need sletchup. Stop being lazy and design it yourself
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 881 Guests (See full list)
