DC Sound Lab
Ok so i have a lvl 2m2 8 that i need to recone. I have the recone already but before i get started does anyone have any tips since this is my first recone. Any help or suggestions would be greatly appreciated! Thank you in advance!
make sure you have it centered very well, use wooden shimms to get that coil perfectly centered around that pole piece in the gap. whaen you glue on surround gently press in center or equally around cone striahgt down and make sure there is no rubbing coming from anywhere, mainly coil. let dry with a little weight on cone so glue tacts sufficiently on spider and basket and on surround and basket!! after sufficient drying lets hear it!!
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
First of all: do you know how to do a recone?
I'll assume you do :)
I like to use a wire brush+drill and get every speck of paint/glue off
Shim the coil as much as you can
An inverted bowl with a gallon jug on top makes a great weight
Take a silver sharpie / tape and mark the alignment of the surround+basket so your tinsels line up right
Put CA glue on the spider landing after getting it shimmed, weigh it down, THEN spray your activator (don't spray it on the spider then begin gluing like some people do)
Pulling off the excess spider and glue with a pair of pliers really makes glue removal easier
Don't forget to tape off the gap. Don't forget to clean it out with a piece of tape.
Edited by SnowDrifter
I've also seen people use spring clamps placed all around on the surround and on the spiders. Would that be a good idea? Although i don't have much room since it is an 8.
I know the basics of doing a recone. I've read a few things about it and watched a vid or 2. Just trying to get all the info i can so i don't screw it up ya know. Im on a tight budget can't really afford to screw it up.
i have never seen a wooden shim used to recone a sub..
1998 gmc extd cab
12 crossfire C710s
4 SAZ-4500s
3 Singer 400A alts
buncha mids/highs
Team Asshole
  • Who's Online   0 Members, 0 Anonymous, 6223 Guests (See full list)
