OMG FI BTL Cracked magnet what to do !!!!!!!
but the magnet shifted off a little bit by like half a inch
Align it back as good as possible, push down on the cone and see if theres any coil rub. Then tape the shit out of it lol.
Yeah its rubbin like crazy Im thinking about grabbing a rubber mallet and bumping it back into place
Shit happens, if its yours then rig it too work best you can. If its someone else's however, you should replace it. Careless installer is still a responsible installer, I would be pissed if someone dropped my shiz and then duct taped it. You can align it with bar clamps, then CA glue best you can.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
nahh its my btl I would not even be on here if it was someone elses
Did you drop it? Duct tape that shit.
lol duct tape fixes everything!
that sucks man.....
Electrical tape is what I used on a Q that was cracked all the way around, and could rotate it around. Its still playin to this day :) As long as you dont get coil rub it should be fine.
or you could just try and CA it all the way around. just try and avoid coil rub as stated before
I Got the magnet centered and tested the coil to see if it was rubbing together so after testing I put a layer of jbweld around the crack of the magnet and now im going to wait for it to dry to tape it. I will give you guys a update tommorow cross your fingers !!
i too will play it till it need some attention
REFF'S
My link
EBAY
lost some motor force, but will work fine for the most part. Glue the crap out of it and have fun while it lasts..
wish "high" end manufacturers would bolt the motors together so this shit wouldnt happen.
Hammerdown... 1%
  • Who's Online   1 Member, 0 Anonymous, 2098 Guests (See full list)
