Eq's helpfull or not?
Guest DC Power Kyle
Eq's make a big difference in sound quality if tuned properly and in a sense, will allow you to play louder while sounding better.
As for an EQ, depends how much you want to spend. I love the bit one.. but it's expensive. The more bands the better.
I would like to add that an EQ can be a mixed blessing. They are nice for boosting or cutting frequencies that need either, but you may find that you are constantly tweaking it for different recordings. Some artists just sound different than others and you really don't want to be tweaking it while driving. Just my experience. Also you may want to take someone with you while driving down the highway and have them adjust settings, because it may sound better one way with road noise and such than it does while just sitting in your driveway.
is it worth getting, over say my old pioneer build in eq? obvious the higher n rca voltage out..
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
You shouldn't boost frequencies with a EQ, only cut.
To the OP, you won't get louder with a EQ, and i doubt you would want to spend money to get a decent one.
I agree with only cutting levels, but sometimes a guy has to do what a guy has to do. ever so slightly boosting a level can be safe you just have to do as little as possible. In the interest not introducing distortion into the signal. The best solution is of course if you are lacking in a certain freq range get speakers that cover those ranges and add them to your system. not trying to sound argumentative here.
higher output voltage is nice as long as you can adjust it to match your amp. No use in 7v outs if your amp only takes 5v max.
Lets asume we have more then 1 sub or highs amp. do that change anything like needing 7v or is it the same for all amps?
Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
