Well my friend has a high mileage 01 grand cherokee with the 4.0l inline 6 and she went to start it and it just would turn over and not fire. But she said her dad was able to start it by mashing on the gas pedal, and drove it home. He thinks it is the fuel pump, but i highly doubt that, but would it be something like a clogged screen or filter inline or something totally different?
Try starting it off starting fluid and if that's the only way to get it to run, could very well be the fuel pump. Check the fuel filter as well for shuts and giggles.
formerly known as Jaylor Swift
could be just a fuel filter clogged imo..... maybe even a clogged injector. i had a 94 cherokee that would do that sometimes too.....i always got it started like that. also i would check vacuum lines for leaks as well as the intake manifold. having a vacuum leak will cause starting issues because there are alot of sensors controlled by vacuum amongst other reasons lol
good luck!
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
That doesn't matter lol, when my fuel pump was failing in my Caprice I had trouble starting it, esp hot starts, once it started though it was fine.
2015 Mazda 6
JVF Customz 4.0 Proto 15>Wolfram W4500 @ .5ohm
2 Sundown Neo 6.5 + 2 CT Meso Tweeters (Front) x Kicker KS6.5 (Rear)>JL Audio VX400/4i
NSB-AMG35 (front) / 40ah Lithium Headway (Rear) built by Erni Audio & Electrical
to check the fuel pump have someone at the back listening and someone just turn the key but not to start if you here a noise fuel pump is fine
