2010 Mustang GT Walled; It Was Fun, Time to go Fast
I just make one hole an oval so you can put the allthread in at an angel just one side then you can get the whoel allthread in there fill the whole big ass fener washers done I've done this a few times on builds where the box could not go in with all thread on tight fit
hard to explain in text
hmmm i would never use a coupler but thats me you could of made one solid piece work
Wanna elaborate Alpine?
Any joint is a potential weak spot. He's right, but I just couldn't get a single piece to fit.
SMD Super Seller
My Feedback Thread
My logic might be flawed, but I'm really not seeing that coupler being a weak point in the design in any way.
The only reason I say that is pretty much summed up in a picture like this.
If a coupler is good enough for a job like the picture above, I don't see why it wouldn't be good for an instance that will never see over 200 PSI in its life.
Where the metal rod touches the wooden dowel at 90 degrees, you can wrap a bunch of fiberglass to connect the two. That will absolutely prevent the metal rod from bowing up and down.
They are actually further apart than it looks. I might think of something though. Its already louder with the all thread, but every little thing helps.
SMD Super Seller
My Feedback Thread
That coupler is fine, the only thing that could possibly happen with it is it vibrates loose and unthreads itself. There is NO way that coupler is a weak spot.
I put nuts on either end of it so it shouldn't come loose. And its definitely an improvement over the dowel.
SMD Super Seller
My Feedback Thread
If your happy with sound...only thing I would add.is a coat or 2 of resin on the entire inside of box to get it as smooth as possible or just paint it..I gained a few tenths..its all about airflow so smooth is best
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
