just curious if there is any special care needed for bead lock rims and if you can even use them on the road
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
should be a problem as far as special car, they are meant to be "off road use only" but then alot of thing now a days are
i doubt you would get a ticket for it
yeah i was wondering about the legality of them, i like the fact that you can mount your own tires even though i would still need to get them balanced. but i'm thinking of just going with a simulated beadlock now
I knew a guy that ran bead locks on his Toyota 4runner, and it was his daily commuter. He said the had to put a little air in them every few days but he didn't ever have any issues with them as far as I know.
You need to tighten the bead-bolts on them periodically to the proper torque spec (don't remember the interval though)
I got a Jeep wrangler, I personally do not have beadlocks but my neighbor is all into the offroading and he has 15" beadlocks on his jeep and he drives them on the street everyday no issues. He has soft 8 cragars
balancing is the main issue in DD's we've run bead locks on the race car, and driven it on the street.
but after two or three tightenings, you should be fine
you can balance it with tape weights along the center of the back of the wheel
  • Who's Online   0 Members, 0 Anonymous, 482 Guests (See full list)
