You wall off the vehicle usually to the b pillar, sealed off, with subs and port firing forward.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
You pretty much build a box that will give you the most air space possible, then cover it with some sort of trim panel to make it look all neat and to seal off the cabin airspace
Like this:
Edited by SnowDrifter
it means instead of having a box in your cabin space the cabin space is the box.
Headunit - Sony DSX-200X
Subs - (2) Modified American Bass 18's
Monoamp - DD M4
Front Stage - CDT HD62-AS components with
4 Crescendo PWX 6.5
4 Channel Amp - Hifonics ZRX1000.4
Cadence 0 gauge
Singer 275 amp Alt
D7500 XS Power battery
Quad 1/0 input Toolmaker terminals
SMD OM-1
RGB LEDs
BUILD LOG CURRENT ABOVE SETUP http://www.stevemeadedesigns.com/board/topic/191602-2003-bravada-2-18s-ab-dd-xs-singer/
BUILD LOG (2 MTX 7512's)http://www.stevemead...__fromsearch__1[/size]
your on a website that there at least 50 (more im sure just a number lol) walled vehicles with build logs... look around
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
i'm on 3rd wall haha
walled off explorer with 4- 15s
you can also wall off a trunk by sealing off trunk completely
(not mine)
R.I.P!
(Nov-29-2009)
92 explorer
current build
Alot, Max depth, how wide you can fit, and the max height. Then all of the ussual box calculations then this and that. Reseach bro.
Edited by wheres the flex at
2001 Nissan Frontier3/5 drop
''Gutted"
Underconstruction
If you don't let your unborn swim in her mouth someone else will.
  • Who's Online   0 Members, 0 Anonymous, 852 Guests (See full list)
