SR20DAZE Posted March 15, 2012 Report Share Posted March 15, 2012 Ok ill try to make this sound as simple a possible I have a rf power 1000 5 channel "newer casing" i have a component set on each of the 4 high channels. I want to get mor power to my speakers by wiring down from 4 to 2. Doing so i was thinking of running tweets on the front channels and midbass on rear channel. All speakers are 4 ohms without crossovers. So it would be 4+4 on the left and same for right, ending in a 2 ohm load per channel. Question one is can i do it safely without a external crossover since my amp has the x10 button for crossover, or would i need some sort of x over Question two is would i lose any sound quality since the hu i want has 3 output sets. Want to get the pioneer AVIC-X930BT if that helps. Quote Hahah damn cody She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch. you dont find dubstep, dubstep finds you hu: Pioneer MVH - P8300BT mids: Alpine sps-600 all four corners highs: Addictive Audio ECST25A,Memphis PR tweeters back sub: 15 inch crossfire bmf box: 4 cubes at 38 hz amp: Rockford Fosgate Power 1000 25 To Life 140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q) Build Log http://www.stevemead...ima-56k-beware/ Feedback http://www.stevemead...s-bfd-feedback/ Link to comment Share on other sites More sharing options...
White Lightning Posted March 15, 2012 Report Share Posted March 15, 2012 Links to view the specs of your equipment would help ... I've never been one to use Rockfords ao even 5 channel amps .... All 2 channel class AB amps for me ... Yes ... droping ohm loads will lose some Sound Quality, get louder, produce more distortion, and if your amp can hold it safely ... will put more stress on the amp ... especially if the 5th channel is pushing sub duty ... My suggestion would be to run a 4 channel and a separate sub amp ... Quote Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
SR20DAZE Posted March 15, 2012 Author Report Share Posted March 15, 2012 http://www.sonicelectronix.com/item_9798_Rockford-Fosgate-POWER-1000.html Is the exact amp i am running And the hu from my first post Compinent sets are still undecided but the current set if compinents i have do read 4 ohms at the mid and 4 at the tweeter. From the leads of the speaker itself, not the crossover As for distortion thats where ray comes in and gets payed to dd1 my stuff lol Quote Hahah damn cody She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch. you dont find dubstep, dubstep finds you hu: Pioneer MVH - P8300BT mids: Alpine sps-600 all four corners highs: Addictive Audio ECST25A,Memphis PR tweeters back sub: 15 inch crossfire bmf box: 4 cubes at 38 hz amp: Rockford Fosgate Power 1000 25 To Life 140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q) Build Log http://www.stevemead...ima-56k-beware/ Feedback http://www.stevemead...s-bfd-feedback/ Link to comment Share on other sites More sharing options...
White Lightning Posted March 15, 2012 Report Share Posted March 15, 2012 (edited) ok ... Amp should be no problem ... anytime you go lower on ohm loads, you create distortion ... the DD1 is only going to tell you to lower your gains to cover up the distortion so you will be back to square one anyways ... So you have a 4 ohm passive component set ... correct ?? how exactly do you plan to make the "Passive" component set drop to 2 ohms ?? possibly change the metrics of the crossover, or replace the crossover (if you can find one) ... If you go active, you will need to replace your drivers so they will have a 2 ohm load ... and ... are you sure you have 4 ohm tweeters anyways ?? might want to check that ... I'm only trying to help ... I'm a Sound Quality guy that is also a Broadband electronics technician ... so you can guess how many numbers are running through my head to add this equasion up ... Edited March 15, 2012 by Cablguy184 Quote Kenwood / HELIX / Linear Power (For The Love Of Music) / Brutal Sounds / OverKill Electric Co Questions About Sound Quality ?? Try Here ... Sound Quality, What does it REALLY mean ?? SMD SOTM Winner "White Lightning" 1997 GMT400 Chevy Silverado "The Green Dickle" 1994 GMT400 Chevy "Phantom Dually" Randal's 2007 Chevy Avalanche (we haven't named this one yet) Dylan's "Brutal" 17 Chevy Cruze RS Hatch Link to comment Share on other sites More sharing options...
SR20DAZE Posted March 15, 2012 Author Report Share Posted March 15, 2012 Yea i have passive sets, what i was thinking of possible was to run the tweets one channel. As in front and rear right tweet on one channel and front and rear left tweet on the kther channel and cross them on the amp with not passive crossover. And the same theory on the midbass for the other two channels. Sorry if im being confusing Quote Hahah damn cody She ain't that sexy. I wouldn't even let her blow me. Those 10 pounds of make up would end up all over my crotch. you dont find dubstep, dubstep finds you hu: Pioneer MVH - P8300BT mids: Alpine sps-600 all four corners highs: Addictive Audio ECST25A,Memphis PR tweeters back sub: 15 inch crossfire bmf box: 4 cubes at 38 hz amp: Rockford Fosgate Power 1000 25 To Life 140.7 on a non sealed trunk car with a five channel so far (old sub audiobahn aw1505q) Build Log http://www.stevemead...ima-56k-beware/ Feedback http://www.stevemead...s-bfd-feedback/ Link to comment Share on other sites More sharing options...
AI James Posted March 15, 2012 Report Share Posted March 15, 2012 figure out what speakers your going to run. then go from there Quote Link to comment Share on other sites More sharing options...
