Computer/Carputer problem (video added)
press f8 when windows first starts to boot
you need to disable system restart on sytem failure so you can see the blue screen code you are getting
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
It does that after you hit last known good configuration?
it sees your drive. Im wondering if its got a bad cmos battery and it doesnt know its supposed to boot from the drive.
Good point. I don't deal with PC's much anymore.
if it was the cmos batt, it would have him press F1 to continue before it went past the POST.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
and you CAN NOT hit the "Safe mode" option? correct?
No, the same thing happens.
I just went to Autozone to get some fuses and recorded a video. It's uploading at the moment, YouTube says 10 more min till it's done.
TEAM FLEX ISSUES
Car: 1985 Oldsmobile Delta 88 Royal
24" Rims
HU: 7" Carputer, Planet Audio EQ, iPhone.
Coax: T3 Audio 4" speakers
Subs: 2x 18" T3 Audio TSNS (walled)
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MB Quarts 6.5" comp set
MAYBE ADDED
2nd DC 9k
well in the blue screen its basically going to tell you that its blue screening due to a recent hardware or driver change, then dump the memory to the HDD..
two things to try that have like a 98% success rate.. pull the computer out of wherever its at and blow the dust off of it, VERY CAREFULLY make sure that there is NO DUST inside the ram slots (where the ram plugs into).
its VERY COMMON that the dust gets into a pci-e slot or ram slot and prevents the BIOS from passing the power test, which blue screens.
the other option is the windows xp disc, you will NEED TO KNOW your operating system in order to get the proper disc.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Here's a vid of everything that happens:
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
follow these steps and see what happens.
also dont be afraid to spam f8 until the screen shows up with advanced options
(the computer still wont work, but it offers important diagnostic information that will be helpful in solving the problem)
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I got the 1st black screen PLUS:
Enable Boot Logging
Enable VGA Mode
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Disable Automatic Restart on System Failure
Reboot
Return to OS Choices Menu
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
"disable automatic restart on system failure"
is the one your after
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I clicked that, now I'm on this screen:
TEAM FLEX ISSUES
24" Rims
Sub Amp: DC 9k
SOON TO COME
T3 Audio 6x9s
MAYBE ADDED
2nd DC 9k
you will be needing a windows xp disc for the next step lol.
do you know what operating system is on there? xp? vista? 7?
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
  • Who's Online   0 Members, 0 Anonymous, 1493 Guests (See full list)
