DHolzman Posted March 16, 2012 Report Posted March 16, 2012 Ok so yesterday my car went crazy on me, i turned it off, took the key out, and the car would still run, only until my toggle switch for my amplifier was turned to off. however when the car was on with the keys in it and i turned the switch off, the bass still remained. i got a new switch, that didnt work, unplugged everything from my amp and plugged it back in, everything went back to normal. now my problem is, without changing any setting on the amplifier, bass level ranges over time and clips at less then half according to the bass knob. before i had it so i could crank it up all the way and bass would remain constant and not clip. can someone help me in diagnosing this problem????? Quote
Robert8252 Posted March 16, 2012 Report Posted March 16, 2012 Pics of your spaghetti mess of wiring? Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
bang'in in ga. Posted March 16, 2012 Report Posted March 16, 2012 Wiring problem.........noway your amp is running the car.................do you have more than one batt.? Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt.
DHolzman Posted March 16, 2012 Author Report Posted March 16, 2012 Wiring problem.........noway your amp is running the car.................do you have more than one batt.? one batt, i have a second one but have not installed it yet, i have fixed the problem with the ignition, but now when i have the volume on my radio turned up to where i always do, the clip light on my bass knob kicks in before half when i used to be able to turn it to full and bass goes from getting extremely loud with a solid clip so getting soft, without any change in volume on deck/knob Quote
bang'in in ga. Posted March 16, 2012 Report Posted March 16, 2012 Could have messed up amp.... Not sure...sounds funny...check all connections...how long have u had ur aq1200? My replacement will be here today....first one they sent was D.O.A. They could of had a bad run of them....... Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt.
DHolzman Posted March 16, 2012 Author Report Posted March 16, 2012 Could have messed up amp.... Not sure...sounds funny...check all connections...how long have u had ur aq1200? My replacement will be here today....first one they sent was D.O.A. They could of had a bad run of them....... ive had it for around a year, i went to a car audio shop out by me and they think that my battery is going bad and to upgrade it, of course for way more then i can get one online, sound fishy?? im going to the auto parts store tomorrow to have them check and see if the battery is still good, otherwise i remain stumped. i talked to kevin at AQ and he said out of all his years of installing hes never heard of something like this happening. gotta find the recipt, hopefully the amp is still under warrenty for a little wile longer. Quote
mattc3366 Posted March 17, 2012 Report Posted March 17, 2012 Those clip lights arnt always known to be very accurate I've heard. Quote subwoofers - two eclipse 88120s box - 3.4 cubes tuned to 32 hz amps - aq1200 and pheonix gold zx450 New build : 2 obsidian audio 15s same amp 6.1 cubic foot box tuned to 32 hz in a civic hatch
bang'in in ga. Posted March 17, 2012 Report Posted March 17, 2012 Yea, and Kevin also told me they have never had a DOA amp..........lol.....Mattc is right though the knobs are not always right, get a DD-1, as for the bass coming and going i'm not sure.....just go over it with a fine tooth comb....check all wiring, rca's ect............ Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt.
DHolzman Posted March 18, 2012 Author Report Posted March 18, 2012 fixed the problem, took everything out and looked at the line out converter, its tied into the wireing harness for the stock 8 in the back and the adapter wasnt plugged into the stock sub box, once i plugged that back in i could crank everything back up to where it was before with no problems, now time for the second battery Quote
bang'in in ga. Posted March 20, 2012 Report Posted March 20, 2012 Cool , glad you got it fixed................it's seems to always be the small things.....lol........... Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt.
