Wattage Help
reinke
does any one have a link or something were i can found out the real wattage of one of my amps? is there even a way like with a dmm or something
a/c voltage squared divided by the resistance at normal listening volume
http://www.stevemeadedesigns.com/board/ind...showtopic=29213 "sleeper build"
(1) DC AUDIO Level4XL 10
(2) PowermasterD2700 batteries
ALL FOR SALE
TEAM DC AUDIO
TEAM DIRTFLOORPOOR
on a DMM, when you're setting the gains and all that, check the voltage coming from the channels. take that number, square it, then divide by the resistance. for instance...my amps are set at about 55 volts. 55^2 is 3025. divide that by 1 (cuz it's wired to 1 ohm) and it's still 3025. which is good cuz they're 3000 watt amps :P
i have a chart that has a list of wattage from 100 to 3000 and what the voltage should be from the channels with 1, 1.33, 1.5, 2, 2.67, and 4 ohm resistances and what the voltage should be from the channel with the given resistance. if you want a copy shoot me a PM. it's handy
