For those that do multiple 1/0 runs to the trunk, do you go through firewall?
Well, I'm going to be installing my XP3000 in the trunk soon and was wondering which route you take to get into the trunk.
Currently, I have my 4 Gauge Power Wire going through the rubber firewall. I'm wondering if it would be safe to run multiple wires through it when I do my 1/0 runs.
If I understand correctly, I'm going have to do two positive runs and one negative run to the trunk battery so that makes 3 1/0 wires going through right?
I took out my seats and carpet for my runs, put them through the firewall with gromets, ran them down the middle of the cab along the center console, then to the trunk.
Also usually you want to have the same number of + and - runs.
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
My trunk has like a trim ring thing around the opening so I just went under the bottom of it. I'm going to be doing 4 runs of Shok 1/0 soon and there is room. My car is an '00 Maxima.
TEAM DC
Everything is a 150 on th earometer
Well I guess punching a woman is a good way to test your strength! You never know how strong you are until you cold-cock a woman in the head and break that bitches jaw.
Next time she tries to punch you in the stomach, whip your wiener out and chase her around. Show her who's boss.
Hmm. I have them going through the driver side and my RCA's through the middle console.
Well, I don't think I want to spend $400 on Knu wire, so I'll probably just do the positve runs and ground the trunk battery to the frame of car somewhere.
To the guy above post, how much is Shok wire and is it OFC ?
And are you running the positive and negative runs on top of each other?
Is there a Shok Wire dealer on here?
1 run of neg is still better then frame ground
R.I.P!
(Nov-29-2009)
92 explorer
current build
True. Hmm. I know it's good to be consistent when doing things, but has their been any studies between 1 negative vs 2 negative runs? Does it make a huge difference for a ground run?
Son of a ....
http://www.knukonceptz.com/productMaster.cfm?category=Kolossus%20Fleks%20Kable
Knukonceptz is out of their 1/0 Wires lol
It looks like I'll have to wait on this project.
I was hoping to have my wire runs done before I buy my DC Power 270A.
If you have any extra after the 3 runs, do 1 more ground to frame in back. So 2 pos front to back, 1 neg front to back 1 neg back to frame
1997 Chevrolet Silverado Extended Cab, 350 Vortec
Things to come at some point...
Build Log: http://www.stevemead...2200ds-133-ohm/
  • Who's Online   0 Members, 0 Anonymous, 1637 Guests (See full list)
