For those that do multiple 1/0 runs to the trunk, do you go through firewall?
Honestly, it may cost a bit more money, but you'd save yourself a ton of headaches if you were to do full runs of negative to the front batt. But what you have seems to be on track, and yes fuse the 2 runs going from the battery to the DC amp according to it's draw. I'm assuming either 200 or 250x2
Ah. So there's a competition coming up. Wow. I chose a hell of a time to do an SPL build and I don't even compete :(
As for your runs, if you have 3 positive runs wouldn't it be better to have 3 negative runs also since current flow in a loop?
What kind of wire are you using?
As for Shok Wires, I've e-mailed the company and they said this:
"the new comp series will be a 5285 strand count full copper cable and will have a new combination (strand layout will be different and upgraded aka Beefier) i'm pushing for the cables to be ready for shipping in May. "
Well I guess for now I'll just chill and wait for everything to come back into production since I'm also waiting on a 270A DC Power Alt for my engine.
My goal is to have everything done by end of June.
So,
D2400 Hood Batt--> 2x 1/0 Power Wire Run --> 2x 300A Fuse Holders --> Trunk --> 2x 300A Fuse Holders --> XP3000 Trunk Batt
XP3000 Trunk Batt --> 2x 1/0 Wire Power Run --> 2x 300A Fuse Holder --> DC5K Amp (Assuming the 5k Amp that I get will require 2x Power Runs)
XP3000 Trunk Batt --> 1x 1/0 Wire Power Run Power --> 1x 300A Fuse Holder -->PPi P900.4 Amp
DC5k Amp --> 1x 1/0 Wire Ground Run --> Distribution Ground Fuse Block? --> Frame
PPi P900.4 Amp --> 1x 1/0 Wire Ground Run --> Same Distribution Ground Fuse Block --> Frame
So I need,
7x Inline 300A Fuse Holders & 1 Distribution Ground Block or more?
Can someone help me with the diagram here?
Can't I just use a distribution block somewhere in this equation to cut down on the Inline Fuse Holders?
Also, should I use some 4 Gauge wire during the amp part in the trunk or should I stick with all 1/0 Wire?
Oh I'm also guessing the Fuse Holder or Distribution blocks for the powers on the amp will not be 300A and will be something else according to the Amp fuse ratings?
Im still waiting on some fuse holders but this is how my truck will be wired, knu kca 1/0 for everything except alt to batt which is 4/0 welding wire and 4 channel to batt which is knu kca 4awg
quick ms paint drawing lol
Used to have a loud truck
So I've decided to just buy 100ft of 1/0 Wire (Might go with Shok's new comp wire when they get it in).
My question regarding my wiring is, should I skip the distribution block and just run two wires from trunk battery to 2x fuse then to amp and then another run from trunk batt to fuse#3 and amp#2?
As for grounding, should the amps in the trunk be grounded to the trunk battery? I've noticed most people grounding the trunk battery to the frame of trunk and then grounding the amps to that same frame.
Here's my diagram:
http://forum.edesignaudio.com/picture.php?albumid=363&pictureid=5216
Good choice going with a big spool of wire. Regardless of mfg (as long as its ofc) you will thank yourself when you have a spool instead of 18' strands and end up needing 19' because of a turn that you didnt notice. And yes ground the amps to the trunk batt. Its right there and its the path of least resistance back to the batt.
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
As far as the original 4 AWG wire that I already have, would it make any difference if I use it with the 2 Positve runs of 1/0 AWG or should I just take it out for wiring the other amp with 4AWG.
Will current flow in all 3 wires or will it totally ignore that 4AWG and take the other 2 paths?
i ran runs of 0g in my beretta took seats and carpet out
i actually had to drill holes in the firewall bc a beretta doesnt have any holes that coulc be used.. then after 2 runs of 0g in i laid down a layer of peel n seal to secure everything etc (got second skin everywhere else but the floor of car )
ive seen many guys who have 4 plus runs they run em under the car or truck
You don't really need that frame ground for your rear battery, although there's no such thing as too many grounds it may introduce noise.
Just do 2 runs of + and - from your front battery to rear, fusing each end. Then run fused power runs from your back battery to both amps, and ground your amps to your back battery, which in turn grounds them to your front battery. I think you might've been overcomplicating it. :P
Thanks. I've got it down now. Next step is to see if I can fit all 4 wires through that rubber thing for the streering wheel.
The Knu Inline Fuse holders are too pricey... $19.99. What kind of price should I be aiming for with Fuse Holders? $15.00 ea?
Ebay ANL fuse holders. Sort by lowest price. Buy. Be happy..
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
ADDING
coming soon..
  • Who's Online   0 Members, 0 Anonymous, 912 Guests (See full list)
