Amart88 Posted March 18, 2012 Report Posted March 18, 2012 I will be running 8 Ga speaker wire to my btl 15's through the back of my wall. I plan on just dilling a tight fit hole for the wire to go through direct without using bolts and then silicone it after. My question is how do you guys like to route the wires when they are inside the box? let em' dangle or pin them up or what?. and how far out past the baffle should they extend to get the woofer out? Thanks My 2005 s10 blazer build. 4 zcon 18's walled.
PowerHouse407 Posted April 3, 2012 Report Posted April 3, 2012 I just drilled the holes and Siliconed the wires and they are just chillen in the box i just taped them really well and had no problems. 2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood Mike Singer 250A SHCA and KnuKonceptz wire Big 4+ AQ / Dayton pro mids+monsoon tweets My Build : http://www.stevemead...35#entry1989435
JeepGuy Posted April 3, 2012 Report Posted April 3, 2012 When I run them through the box, I just let them dangle. And I would just put some silicone around the drill hole and no air will escape. - 1995 Jeep Wrangler - ALL UNDER MASS TRANSFORMATION!
MrSkippyJ Posted April 3, 2012 Report Posted April 3, 2012 that or bolts and nuts, either way will work fine. bolts and nuts makes it easier to deal with wires later on if you ever needed too. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
