well i have a 92 toyota extended cab pickup. it has new speakers in the front and added kicker 6.5's in the back i have 1 polk dxi 10" on 700w. im tryin to get as loud as i can. I was thinking going to a high end 12 or a 15 (any recomendations?) . im going to build my box at school for a shop project. im not going to use the back seat so any thing behind the front seats is bass space. im lookin for some pointers or tricks to get the most spl .
Thanks
BOOZE IS FOOD
i know these small extended cab trucks can get pretty loud easily. im not shure of budget yet probly around 600$ would like to keep a single sub setup
BOOZE IS FOOD
If you want a single sub. Go with a 15 and the most power you can afford. Sub firing forward in a ported box with port firing up.
On $600 you dont have much to choose from for a sub, amp, wire, and upgraded battery. My suggestion is to search for deals on used woofers and amps around the 1000w rms range, get some beefy 4-0awg wire and good connectors.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
i found a 12" alphasonik mayhem for sale in good condition for cheap would it be worth it? if not what would you guys recomend for a good 15.
the truck already has new deep cycle battery, volt meter, and big 3. would i need another battey
i have 4g wire.
the 600$ would be for the sub and amp nothing else
Edited by Mr.Aircooled
BOOZE IS FOOD
best way to get that truck loud is going to be a 15 or a 12 with sub up and using aeroports firing off the passenger side wall ;)
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
600 bucks? for sub and amp?...id get a aq hdc3 15 and a aq1200 rright around your budget and will bump i promise
1999 grand prix gt
kenwood x994 head unit
1/0 big 3 all shok industry single run to the back
New mid/highs coming not sure what
Soundqubed q2200d at .5 (have)
2 soundqubed hdc3 12s (have)
New box to be built.. sealed firing forward (yet to be designed)
200 amp alt not sure exact size or manufactor xs power batts
im going with a 15 havent decided wich one yet. wich way should i fire the sub twards the back of the seat or up and i should aim the port twards the passenger side right
BOOZE IS FOOD
Ed answered that question a few posts up. Trust his words. He is a wise man.
-98' Ford Expedition (Rest in Peace)
-AVH-P3300BT
-Crescendo BC5500
-4 18" DC m2 Level 3.
ive seen both set ups work both sup up ported to the side and sub forward port up
power: dd m4
  • Who's Online   0 Members, 0 Anonymous, 1579 Guests (See full list)
