okay so i got some new subs and amp cheap i couldnt pass up the deal. but i need help on how i should wire them.
so i got 2 of the new p3 12s
http://www.rockfordf...x?itemid=120421
and this amp
http://www.rockfordf...x?itemid=116138
the subs will be in a custom built down fire ported enclosure for underneath the back seat of my silverado. its not a regular box before any one says i need a bigger box. this box is huge about 1.8 cubic feet for each side.
so if i could just get some feedback on the best way to wires these it would really help.
Edited by WICK3DxGATA
99 Gmc sierra extended cab
front speakers: DB drive 6.5
back speakers: DB drive 6.5
amp: none right not
subs: none right now
Future
waiting to get my 2 skar vvw 8s installed
sorry they are 2 ohm subs
amp: none right not
Future
well unfortunately with two dual 2 ohms subs your wiring options are limited to .5 ohm, 2 ohms, or 8 ohms. Taking into account impedance rise you might be able to get away with .5 ohms on that amp. If it goes into protect, you will need to wire it to 2 ohms.
to get .5 ohms, wire it in series, by connecting all of the positives together and the negative together, and then to the amp.
to get 2 ohms, you need to wire it in a series parallel configuration by jumping a positive and negative on each sub, and then connecting the remaining positive, and negatives to the amp output.
well would it be better if i traded the two ohms in to get the 4 ohms?
amp: none right not
Future
Yes, trade them in and get dual 4s. DONNNNNNT wire that amp at .5 ohms, it'll go into protect. Dual 4s will wire for a final ohm load of 1 ohm and will get the most power of that amp.
okay so if i trade them in for the 4 ohms how would i wire them?
amp: none right not
Future
