i put the 2 ap 1500's in today and when i was tunning them with the dd-1 i couldnt turn the gain up. i checked the headunit and it wasnt distorting but when i would hook up the amps (strapped) it said it was distorting with gain and bass boost all the way doww. what do you guys think it could be?
EDIT:
the equipment is ...
kenwood kdc-448u
2 audiopipe ap1500's
2 runs of knu 1/0 to battery and memphis 4gauge from battery to amps.
cadence 6ft rca's to amps
Edited by jake1993
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
What are the bass and sub level set to on the head unit?
flat.
i pulled it out and put a alpine in with settings flat and it still did the same thing
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
low pass want all the way up. but was like 50hz.
Jacob Sigmund
1 dc level 4 m1 18
1 audiopipe ap1500
2 runs of knu 1/0
If the amps are strapped, don't you only set the gain on the master?
Check both individually. Use the one that has the LEAST gain as the master. Then just set the settings on the master.
Your second amp is on slave mode, right?
SMD Super Seller
My Feedback Thread
I knew before I even opeend this it was gonna be an audiopipe amp.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
