Hey guys, I am working on designing a new enclosure for a pair of 12's. Total displacement is .47 of the enclosure for subs and angles.
The specs are 36" W x 20" D x 13.5" H
I was thinking 2- 4"x 16" aeroports dead center in the enclosure.
According to my math, tuning should be around 30hz.
If someone could assist me in this that would be great as I dont have a computer so I cant use torres' box calculater as I am on mobile!
Thanks guys
Mike
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
What would you recommend to adjust accordingly? The subs really only need 1.75 ported each.
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
A single side mounted 6" aero and reducing the width of the box to 35 would leave you 3.5 cubic feet of net volume, 30.5 Hz of tuning and 8.1 square inches per cube of port area.which would be acceptable for low to medium power/excursion subs, but if you really have 0.47 cubes of subs/bracing displacement maybe those are high power subs, in that case 8.1 square inches per cube may be low if you want good efficiency.
I am open to all opinions! A side mount port is not gonna work as its a trunk car and will be sealed off! So port/sub forward is most desireable! Also I like low tuning and good efficiency as I am looking for more SQL!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
Vehicle is a 98 Mercury Sable! I normally drive with the rear seats down, so firing forward has been actually louder during my testing. My front stage is still a work in progress, running off the headunit right now!
Plus working on a budget, I still havent deadened the car yet and dont plan to till prolly fall!
The enclosure I have in there now, is a single sub setup, that is 13.5H x 18D x 26.5W with a 12" x 2.5 x 30" port tuned to 29hz.
I was thinking running an aeroport to save on space so not to have as big of an enclosure!
Pioneer AVH480
Onyx Subwoofer
Sky High OFC wiring
  • Who's Online   0 Members, 0 Anonymous, 2930 Guests (See full list)
