gally Posted March 26, 2012 Report Share Posted March 26, 2012 So i currently have a Re audio SE10˝in my trunk which is being powered by an Alpine Mrp M1000, at 2 ohm (sub is D4 wired down to 2 ohms) The sub is packed in a sealed box, and there is no air leaking between the sub or the box (checked that first). my connections are also good, the weird thing starts when i start playing some music at low volumes and the Sub starts with a popping noise could it be possibly that one of the tinsel leads slaps? or is there any other problem? i will upload a video of the sub popping tomorrow when i get the chance... thanks in advance Quote 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
gally Posted March 26, 2012 Author Report Share Posted March 26, 2012 any help?? Quote 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
Guest Posted March 26, 2012 Report Share Posted March 26, 2012 weird...try taking the sub out and playing it at volume that would normally cause the popping. see if it causes it then. if it does you could probably pinpoint it a little better where its coming from Quote Link to comment Share on other sites More sharing options...
bang'in in ga. Posted March 26, 2012 Report Share Posted March 26, 2012 I had 2 - RE sex 12 dvc 4's that did the same thing, mine was tinsel slap,,,, now i wont own a sub that doesn't have sewn in tinsels......... Quote Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO Pioneer DEH-3400-UB Vega 65 cs & 1" tweets & T3 4" coax in Front 1- Dual 300 with an AQ sticker 2-AQ sdc2.5 12's 1- AQ 1200D.1 Monster Cable RCA's Monster Cable 4-awg Custom 4 th order box ( by DBC ) Crescendo FT1's in rear- 1/0 Big Three Opti Blue top in back for Mono Amp Stinger Power dis. block 125 amp breaker at front batt. Stock Alt. Link to comment Share on other sites More sharing options...
gally Posted March 27, 2012 Author Report Share Posted March 27, 2012 I had 2 - RE sex 12 dvc 4's that did the same thing, mine was tinsel slap,,,, now i wont own a sub that doesn't have sewn in tinsels......... mine is the older model of the SE series....i had that sub for over 2 years(+2years in garage) and it banged... checked the sub and the tinsel leads are fine........dont know what is it...but when i play the sub without the box it still pops.. Quote 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
CleanSierra Posted March 27, 2012 Report Share Posted March 27, 2012 Signal issue from the HU? Try different RCAa yet? How's the ground on the HU? Quote Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
CHEVY4X4BLAZER Posted March 27, 2012 Report Share Posted March 27, 2012 Any coil rub? How are the spiders and surround? Quote Link to comment Share on other sites More sharing options...
gally Posted March 27, 2012 Author Report Share Posted March 27, 2012 Signal issue from the HU? Try different RCAa yet? How's the ground on the HU? no issue with the HU and already tried the RCAs the surround and the spiders are fine woudnt know what is it.... Quote 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
gally Posted March 27, 2012 Author Report Share Posted March 27, 2012 video comin up tomorrow.....gonna check the sub again... Quote 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
Autruche Posted March 27, 2012 Report Share Posted March 27, 2012 Try a different sub. Then you'll know whether it's the sub or the amp. I've seen it happen when people have had their subs wired ridiculously low, or the amp isn't getting good voltage. Try grounding it in a different spot. If it is an actual popping noise try to look at the coil if you can. You may have 'slinky'd' it and it is shorting out on itself. Quote Need Test Tones/Sine Waves? Click Here!My Saab 9000 build1993 Saab 9000 Aero 5spdPioneer - Zapco - Hifonics - Sundown Audio - O2 Audio - RE AudioJust Say No To Rear SpeakersJust Say No To CCA WireReal Men Drive StickHit me up on Facebook, if you want Link to comment Share on other sites More sharing options...
