Hey everybody, I've got a quick question. I've got 2 re sxx 12's running off 2 arc ks 1000.1's and the low bass sounds pretty terrible. I know the amp settings aren't the problems. the gain is MAYBE 1/8th of the way up. The bass boost is all the way off and crossover frequency is set to 80 hz. I am having a hard time finding the problem here. The box is right at 4 cu ft. and tuned to 30 hz. The setup is in the hatch of my 350z. Also when the bass hits, the box comes completely off the floor. I think this may be half the problem. Also, any ideas how to hold my box down without drilling holes in the floor? there is no carpet so velcro won't work, thanks!
Audio Build
Ride: 2002 Chevy Blazer 4 door
Head Unit: Pioneer deh-80prs
Subs: 4 DC Level 3 15's in a 4th order wall designed by Trent Choate and Jeff Smith
Subs Amp: AQ 3500.1 at wired at .5 (soon to be 2)
Mids/Highs Amp: Skar 85.4
Mids/Highs: Skar components
Electrical: Mechman 270 amp alt, 2 runs of Knu 0 gauge, XS Power d3400, 2 Deka Group 9a31
Build log : http://www.stevemeadedesigns.com/board/topic/167658-indianabasshead-blazer-dc-audio-4th-order-wall-build/
Perfomance Build
2003 Nissan 350z
Greddy Twin Turbo, 3" Test pipes with Borla high-flow cats, Crawford Performance Plenum, Greddy E-manage Ultimate ECU
Exedy Racing Clutch, Built Motor by Racing Innovations
Greddy Over-fender aero kit (1 of 20 ever made), 19" Racing Hart r5 pro wheels
466rwhp
Bike
2008 Midnight Blue Kawasaki ZX-14
Stretched 8" and lowered, Brocks Sidewinder exhaust, Power Commander 5
large sheet of mdf under the box, screw box to sheet of mdf.
this is called a "false floor"
you could also not have enough port.
i dont know anything about arc audio.
wheres your subsonic set at?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
thanks a lot everybody! Only problem with putting down false floor is I can't get the box out of my car.. It was built inside. But I will just use L brackets and bolt them into the floor of the car. And the subsonic is set to 25 hz.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
lift the box up and slide mdf in?
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
I mean it sounds that easy but its really not. I cant really lift the box up more than an inch or two. It's built against the strut bar in the back of the car. I'm not sure if you're familiar with 350z's or not. I will definitely give that a try though.
Audio Build
Perfomance Build
2003 Nissan 350z
466rwhp
Bike
im not familiar with a 350z.
you could try 1/2" mdf instead of 3/4" though.
just trying to give you ways not to destroy your car lol
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
your box jumping up is one problem. it hitting the lows is another problem whether it be the box or maybe loading issues off back of car it theres no breathing roomb, etc. it could be many things. l bracks will hold your box down. then give an update. i dont see how your box moving will effect the sound too much. i see it taking away from SPL but it should still produce lowend if designed right
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
  • Who's Online   0 Members, 0 Anonymous, 2293 Guests (See full list)
