RCA Preout Help!
Look, this what you do, take one stick of T-N-T ...... light it, throw it into the car and run...prob. solved............
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
It isn't the preout voltage being 2v. You should hear the sub on volume 1 which is waaaaaaaaay lower than the 2v max rating on the preout. I'm betting there is a wiring issue you are overlooking or a bad hu output. Try the speaker level inputs instead of the rca outputs.
the sub out/rear out setting pops up when the headunit is off.
Current Setup: , 2 Fi sp4 18s in a big ass flat wall tuned to 23hz, Pioneer 80prs, 2 Digital Designs m3bs strapped @ 2 ohms, Banda ICE2000, Crescendo 800.4, 4 PRV 10MR1000s,4 Mclaren MLT300 Super Tweeters Kinetik 2000 XS Power 2700 & XS Power 3100s.
yea i have already been through that with him. he said it doesnt show up. im guessing cuz it has 3 sets of pre outs instead of just front and rear/sub. (not counting the bus in rca's)
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
the subwoofer option doesnt even show up? In case you didnt, you probably have to turn off the headunit, or standby to get to that option in the menu
yea i told him about that
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
  • Who's Online   0 Members, 0 Anonymous, 984 Guests (See full list)
