Fi Car Audio
Question about the SP4's
Boomzilla
Hi guys, having a dilema.
Because of my vehicles power limitation(explorer v6) ie can't find anyone to build an alternator bracket for the 2 extra alternators I need to run 3 total, I am limited to just 2 3400d's instead of 4.
So the question is this: How much power is needed minimum to make the sp4's work properly(i didn't know how to word it).
I can either go with 3400rms each to 2 18's, or 1700rms each to 4 18's. I'll have about 6.5-7ft exactly each. I wanted to go with 4 18's and with 4 amps3400d's(soundstream dtr towers) but electrical isn't there, so with 2x3400d'[email protected] each, what do you think? Is 1700rms each enough? 2 18's or 4 18's? Thank you.
2004 Ford Explorer
2x Soundstream Tarantula DTR1.3400D(3400Watts RMS @half ohm each)
2x Fi SP4 18"
0 Gauge(aquired)
Mechman 270Amp alternator
4x Kinetik2400(Needs starting battery)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
I honestly would go w/ 4 BTL 18's for that setup if you really wanna go with 4 18's. Or do the 2 SP4's.
TEAM Fi CAR AUDIO/ TEAM CRESCENDO AUDIO
Bagged '06 Dodge Magnum R/T "WICKED WAYS"
-4 Fi SP4 18's (4th Order)
-2 Fi SSD 10's (midbass)
-4 Diamond Audio D6 Comp Sets
-1pr. Crescendo FT-1 Supertweets
-Dual Alts -6 XS Power Batts
-4 Crescendo BC3500d's (subs)
-1 Crescendo BC2000d (10's)
-1 Crescendo c1100.4 (comps)
Thought the SP4's were more of a Daily Driver and BTL's were spl subs? so 1700 wouldn't be enough for an SP418?
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
My amps achieve full power 3400rms at 0.5ohms Soundstream DTR1.3400D
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
Fi audios recones come dual 1s that are gonna read. 7, or u get dual 2s and they will read 1.4
Sooo unless ur gonna wire to. 35....
SCSB
Santa Cruz Speaker Box
Build logs:
Daily Driver Lemon Marquis
2 american bass 750.1s
350.4 on 14 focal 6.5s
sq 945 on 4 hertz tweeters
http://www.stevemead...__fromsearch__1
The Mustang 'dubbed' Shirley the project from bullet holes to badass
http://www.stevemead...cond-skin-time/
Can't find anyone to build a custom alternator bracket to run 2 or 3 alternators. I would run 4 but one 270amp alt won't cut it.
70amps per 1000watts.
2004 Ford Explorer
2x Fi SP4 18"
0 Gauge(aquired)
Big3
NEEDS
Box
Head unit
Line Driver
Hi's/Mid's + amps
Amp/Battery Racks
Dynamat
BTL N2's are fine for daily. The N3's are SPL only. The N2's have an RMS of 2000w & the SP4 is 2500w RMS. With 1700w, you're falling shorter from the RMS of the SP4 than if you were doing the BTL's. The BTL's are beasts too man. You'll be happy w/ them too.
  • Who's Online   0 Members, 0 Anonymous, 4114 Guests (See full list)
