so guys this is my build its my 3rd build, the build
CAR: holden vr commodore
FRONT'S
165V30 FOCAL 6.5" TWEETER COVERS WERE REMOVED TO FIT IN THE TOP OF THE DOOR TRIMS DOORTWEETERS.jpg
REARS 2 MB QUART 6X9"S (NOTHING FANCY)
AMPS: FOR THE FRONTS AND REARS SOUNDSTREAM LW4.300E
FOR THE SUBS ECLIPSE ZA1200
AMPS ARE MOUNTED ON FALSE WALL THAT I MADE IN THE SAME CONCEPT AS A WEDGE STYLE BOX JUST WITHOUT THE BACK FOLLOW ON TO SEE HOW I DID IT
SUBS
2 12" KICKER SOLO CLASSICS (600WRMS EACH BUT THERE GETTTING AROUND 550RMS)
BOX
AS THESE SUBS DONT REQUIRE A BEHEMOTH BOX THERE IN 1.76 SQUARE BOX THAT IS FILLED WITH POLLY FILL (PILLOW FILL L.O.L) FRONTVIEWBOX.jpg
POWER UP FRONT THERE IS ONE R&J ULTIMATE BATTERY (AGM)
BIG 3 HAS ALSO BEEN DONE
IN THE REAR THERE IS ONE GEL TEC AGM DEEP CYCLE (WIGHTS A FRIGGEN TON!) WELL LIKE 70LBS
NEXT IS THE FALSE WALL WITH THE AMPS SITTING ON THE BATTERY BOX, THE BATTERY IS SCREWED DOWN TO THE CHASSIS TO AVOID IT TOPPLING OVER
THEN THE WALL IS ADDED AS ABOVE ^
ALL THE POWER WIRE THROUGH THE CAR IS 4GAUGE I WOULD OF LIKED TO HAVE USED 2 OR 0 BUT IT WOULD OF COST ME A FORTUNE ITS MUCH MORE EXPENSIVE IN AUS :(
DUEL BATTERY CHARGING SYSTEM IM NOT SURE ABOUT OTHER SYSTEMS BUT ONCE MY MAIN BATTERY ( UP FRONT) DROPS BELOW 80% CHARGE IT SWITCHES OVER FROM ONE BATTERY TO ANOTHER TO MAINTAIN A CONSTANT 14.4V TO THE AMPS
FUSES
UP FRONT THERE IS ONE 300A THAT IS RUNNING BETWEEN THE FRONT BATTERY AND THE REAR AND ONE 120A FROM THE ALTERNATOR AND THE FRONT BATTERY AND 2 300A FUSES AT THE REAR JUST FOR ADDED SAFETY.
JUST ONE FUSE FOR AN EXAMPLE
DEADENING: NO PROPER SOUND DEADENER WAS USED AS IM ON A BUDGET AND IN AUS DYNAMAT IS ALMOST THE ONLY THING AROUND BUT 1MX1M IS OVER $100 aud SO I USED EXPANDER FOAM ( CAN) AND ITS WORKED FINE TO ELIMINATE MOST OF THE VIBRATIONS.
HEAD UNIT
CLARION DXZ756MC ( OLD SKOOL) OKAY ITS OLD BUT IT WORKS BETTER THAN ANY OTHER UNIT IVE TRIED AND IVE TRIED A SHIT LOAD ! ITS GOT AUX AND A 30GB BUILT IN HDD SO ITS GOOD ENOUGH AND HAS 6V PRE OUTS AND ABOUT EVERY TUNING A PANORMAIC EQ HAS TOO
AND FINALLY TO FINISH IT OFF HOPE U GUYS LIKE IT TOTAL COST WAS $1500 AUS AND ALL BRAND NEW.
HOPE USE ENJOY LET ME KNOW WHAT U THINK GOOD OR BAD IM EASY.......
not bad, for aussie build lol it would probably sound nice, bit sound deadaning to smooth it out.
i miss my vr =/ and vt...lol
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
hey another aussie Welcome, where abouts you from man ?
and your build looks good bro, any vids of it in action ?
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
ohh i forgot to ask man where did you get the dual battery charger thing from ? i want to look into that
redarc do them, there one of the best,
http://redarc.com.au/home
Arb and oppositlock sell them them as there used in there dual battery setup
you can also get projecta, but you will be in replacing it under warranty all the time as there poorly made
http://www.bcf.com.au/online-store/products/Projecta-Dual-Battery-Kit.aspx?pid=283674#Description
Awesome setup Sir ...
  • Who's Online   1 Member, 0 Anonymous, 1115 Guests (See full list)
