i have a red top optima under hood with the big 3 and stock alt thts putting out 14.3. i just put all 1/0 in car if 1 pos and 1 neg to back with 2 xs power d3100 on a dc pai2000.1. it started with my stinger voltmeter reading 13.2 at amp and i thought that was weird so i voltmeter on the termianls on amp and its says 12.4 and my batts just sitting are 12.2 but my optima up front running is reading 13.8 so im wondering if i should do 1 run off the alt to back or other 1 back off the red top or something else?
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
7 Xs D3100s & 1 D6500
All Audio Techinx OFC 1/0
Doing 55s at 26hz!!!
its install bay wire i kno shitty wire but it works all fuses are in
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
and i had extact wire and everything in a 98 monte b4 it died and now put everythin in my camaro so the monte always ran 14.6 so idk
89 Ford Bronco 2
6 DC XL M2 12's
1 DC 9K
Dual Singer Alts
i have a red top optima under hood with the big 3 and stock alt thts putting out 14.3. i just put all 1/0 in car if 1 pos and 1 neg to back with 2 xs power d3100 on a dc pai2000.1. it started with my stinger voltmeter reading 13.2 at amp and i thought that was weird so i voltmeter Is this the same stinger volt meter or a digital multi meter? on the termianls on amp and its says 12.4 and my batts just sitting are 12.2 but my optima up front running is reading 13.8 so im wondering if i should do 1 run off the alt to back or other 1 back off the red top or something else?
well for one 12.2 sucks charge it and bring it up. for two have you checked the fuses please tell me you arent relying on a stinger voltmeter to check your voltage.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
