Renault trafic SQL Build from Scotland ...
after that we needed to fit volt meters in the rear and lighting switch's and the remote trigger switch for the amp that runs the
5" components in the rear as these are not used in SQ
so a hole was cut
and Brax was fitted one at each side as i need symmetry and also a little DLS badge just incase anyone forgot
then a trim for around the old window opening on the bulk head was fabricated stained then griled with grill cloth to keep the rear secret from anyone
looking through the front glass while still letting the bass into the cabin
stained and fitted
components in roof fans fitted and all finished in the rear
except for one very special piece which i will reveal later
I.. am.. speechless.. TUNED IN.
___________________________________________________________________________________
-1997 Oldsmobile Cutlass Supreme Coupe-
-2 12'' Alpine Type R's-
-Sony xPlode Head Unit-
-Planet Audio AC2000.2 Amplifier-
Anarchy Series 2-Channel Amplifier
RMS Power Rating
2 ohms: 700 Watts x 2 chan.
Bridged, 4 ohms: 1400 watts x 1 chan.
I like the configuration of the front seats! Have your girl sit right next to you giving you a little sumthing while going down the road ;)
2004 Bagged Trailblazer
(4)18" Sundown Nsv3s
(4) Taramps HD10000s, Taramps DSP3000, Lanzar opti 250x2, AB 100x4
(2)DC power SP 270s, (14)XS Power d3100s, (1)d6500
The very special piece i mentioned yesterday started out like this
which was the blue print for a One Off Custom rug for the rear off the van ( just for show days ) i must add
the rug was commissioned by one off the guys on Talkaudio uk our forum here , and was hand made on the borders off India
it took 3 months from drawings to delivery at was so worth the wait but please don't ask what i paid for this as I'm taking that info to my grave
and if the wife ever finds out that may come sooner than expected lol
anyway here's the pics i give you the DLS rug
but even the rug meant we had to modify the van to accept it as because off the thickness off the pile around the edges the rug ended up being 1" to wide so it was back
to the drawing board and we got these made again in stainless steel
then it was a case of trimming down the boxes over the wheel arches
much better
but we had a little disaster along the way the weight off the roof tore the rear mountings down the weight up there is near 200lbs
and while hitting a hole in the road the roof bent down
so we welded up a couple off stainless steel supports to stop this happening again
oh and just to prove it still works daily
Tomorrow i'll start the front end build log
Saw this at Modified Nationals and I was so impressed when someone flipped down those amp covers!! Had me completely fooled!
Daniel Brill-Edwards - Representing English Bassheads!!
Old Build Log - http://www.stevemeadedesigns.com/board/topic/94637-vw-golf-mk3-1996-build-from-england/
New build coming soon with SMD V1 #99
YouTube Channel - http://www.youtube.com/brilledwards
