Just feel that my voltage drops to low at idle with the sterep only 1/2 way and gain under 1/2. Voltage drops down way low 13.5 4s. Any way to test a weak alt? Is it possible to damage or weaken an alternator?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
13.4 is good voltage my friend.. Your alternator is perfectly fine and nothing will be damaged
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
at full tilt whats your voltage drop to?
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Put a small load on it and see how much dimming you get/how fast it goes back up to 14+. Roll down both windows, put on A/C, etc.
Honestly, you're drawing a bit of power off stock with that 2200, i'd be happy with 13's
Full tilt i think i ve see 12.6 but on a de af song or so ive seen 11.8 then cut the volume off. Think its time for a new batt this ones 5 years old
lol, that could be it too. Where are you measuring from? I thought my alt was going on my last car but if I measured from alt+ to engine block I got 14.8 while the batt was only seeing 13.8. turned out to be a bad ground :unknw: Just thought I'd throw my experiences out there if it helps you.
My stinger meter is on my amp. At idle they battery and volt meter(amp) match up. I will check the voltage at full tilt on battery and on alt.
at idle your alt probably does like 70 amps. tack on that old ass battery and your symptoms seem completely normal.
  • Who's Online   0 Members, 0 Anonymous, 2044 Guests (See full list)
