Just feel that my voltage drops to low at idle with the sterep only 1/2 way and gain under 1/2. Voltage drops down way low 13.5 4s. Any way to test a weak alt? Is it possible to damage or weaken an alternator?
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
13.4 is good voltage my friend.. Your alternator is perfectly fine and nothing will be damaged
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
Full tilt i think i ve see 12.6 but on a de af song or so ive seen 11.8 then cut the volume off. Think its time for a new batt this ones 5 years old
lol, that could be it too. Where are you measuring from? I thought my alt was going on my last car but if I measured from alt+ to engine block I got 14.8 while the batt was only seeing 13.8. turned out to be a bad ground :unknw: Just thought I'd throw my experiences out there if it helps you.
My stinger meter is on my amp. At idle they battery and volt meter(amp) match up. I will check the voltage at full tilt on battery and on alt.
  • Who's Online   1 Member, 0 Anonymous, 1156 Guests (See full list)
