ill see what happens tomorrow i guess. thanks
Edited by D-train-13k
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
bump for any other opinions
Right ... And then shutting off at mid volume..??? Hmm, anyway to find another amp, and slap it in??! And See what happens.???
i dont have another amp.
run a dc 175.4 and see if it dose the same
Nvm what the op said.lol
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
hope yall are joking.. i just said i didnt have another 4 channel
Shutting off at mid volume has to be an internal issue.
There's no way mid anything should hurt any amp. Mid to me means you can talk normally and it matches the volume.
I don't really know what to say other than warranty it or somehow get another amp to test (yes I know you don't have one, but it's really a good way to eliminate possible causes)
Your grounds are good, and by good I mean they aren't screwed under a seat so there shouldn't be an issue there.
Measure the voltage of THAT amp? I really don't want tot say its your vehicle, cause you know what your doing IMO.
I'm no amp pro or anything but.. Your electrical is good, rcas are good, speakers are good.. Really doesn't leave much.
Ohm load, or an amp issue is all I can guess
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
I just relocated the amp to inside the cab and took it off the side. I measured voltage to see if there was some crazy drop between power and grounds. And it stayed above 14.
The amp is literally brand spanken new.
I hope it was just some thermal issue or something to do with the impedance.
I'm still waiting on UPS to deliver my othe mids but lord knows if they'll get here before 4
honestly do they ever? im lucky if i get my packages by 6 or 7pm
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
Lol yeah it didn't get there until about 8 or so.
But I figured it out. Some connections to the other missing mids were touching and causing the amp to protect. So it runs good
I just didn't see the clips hanging into each other. Stupid things
Oh well. Works and sounds great. Thanks guys.
