So this is just a little explanation of why when we run at .5ohm it takes a big alternator or 2 and a few batts.
If anyone has ever had a 2ohm stable amp and tried to run at 1ohm without sufficient electrical they have probably experienced amp shutdown at volume, but most people don't understand what's going on electrically. The problem is called voltage dip, and it occurs when impedance is very low. As the impedance decreeces the curent increeces, and consistently voltage drops, the problem is literally that the impeeadece is so low the electrons are moving around the circuit so quickly that it's a near short circuit. And as most of us know the way to avoid this is to get a bigger alternator. The biger alternator can provide the curent the amp is asking for to combat voltage dip. The moral of the story is either beef up the electrical or raise your impeadance!
just wondering what made u want to write about this subject?
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Bashing lol.....what about amperage sir? Its not voltage the amp craves its the amperage correct?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
One of my friends was having this problem and nobody could explain why I was just told to get a bigger alt but I couldnt figure out why, so I looked it up an did some research
