El_Wetto Posted April 8, 2012 Report Posted April 8, 2012 I'm not really experiencing the typical "lights dimming" stuff, but my amp is getting exceptionally hot after small periods of time. My setup includes Power: alpine mrp-1000 alpine f-300 HU: kenwood excellon kdc x395 Wire: Rockford 4 Gauge Power & Ground (m1000) stinger 8 gauge from amp to sub Sub: Rockford Fosgate T2 12 D4 in Rockford designed H.O. slot ported enclosure no big three but im running a duralast gold top which has been pretty faithful to me im just wondering basically if a capacitor would help with the heat issue.
AB18VFL Posted April 8, 2012 Report Posted April 8, 2012 ....dont get a cap, get an AGM battery for the rear. SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!! 2005 Subaru Impreza My build log. Head unit- Kenwood Excelon KDC-X695 Front doors- Rockford Fosgate 6.5" Prime components Rear doors- Rockford Fosgate 4" Punch coaxials Sub amp- Audiopipe AP18001d Subs- Two American Bass TNT 10"s Box- 2.6 cubes @ 34hz, 36in of port Big 3 & run of Raptor 1/0 to rear powercell TEAM 808 UPSTATE NY. Can it be heard 2 blocks away, thats how i rate systems.
Quiet Posted April 8, 2012 Report Posted April 8, 2012 ^x2 Please do not get a cap. Put whatever money you would on a cap towards an AGM battery. XS Power, Kinetic, even a Optima yellow top if you have to. Capacitors will tax your alt to no end. It will make it die a slow, torturous death. 2007 Pacifica Rebuild. Less quiet. Still not loud.
bass_stalker Posted April 8, 2012 Report Posted April 8, 2012 bad ground prehaps? whats ohm load are you wired to? i would just advise you to add a large agm battery in the rear JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
El_Wetto Posted April 8, 2012 Author Report Posted April 8, 2012 ....dont get a cap, get an AGM battery for the rear. battery= 2x amount of fuses & fuse holders? already have a cap. monster 1 farad digital. havent installed yet. might flip it on craigslist.
Quiet Posted April 8, 2012 Report Posted April 8, 2012 Yeah, you need more fusing. What amps are you running and what gauge and brand of wire? Could be a bad ground but if you haven't done the big 3 you got work to do. 2007 Pacifica Rebuild. Less quiet. Still not loud.
El_Wetto Posted April 8, 2012 Author Report Posted April 8, 2012 2 ohm load. car will probably be out of commission for a month or so due to a possible b16 swap so im kinda thinking temporary fix with stuff i already have
El_Wetto Posted April 8, 2012 Author Report Posted April 8, 2012 alpine mrp1000 rockford 4 gauge stinger 100amp anl fuse
michigancapri92 Posted April 8, 2012 Report Posted April 8, 2012 what you swapping 16g into ? Teamcapri.comThe TeamCapri 1992 Mercury Capri XR22012 FORD EDGE SQ BUILDOld build logMy FeedBack1992 Mercury capri XR2 Hyper LED
