Grounding Amps
Amart88
A good chassis ground will be perfect. To the frame is best not to the body
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
Well in your case the body will work
Unibody cars are horrible to ground to. The reason is, they use glue to make all those joint connections. I would suggest running a ground back to the battery.
Yeah, my stock batt is in the trunk anyways. So the factory ground in in the trunk :) I checked it with DMM and it seems good. So if i wanted to make another one i would just sand the metal bare anywhere? and check with dmm? God damn unibody cars. I assume the factory ground would be solid. I hope.
Factory grounds are fine for the car, but can be an issue for aftermarket gear. You would be better off grounding to the battery since it's there. I would suggest that at some point you do a big 3, In your case it means running both pos and a ground from the alt to the battery all the way in the back. It will help your overall charging system quite a bit.
Yeah already done. Heres a small vid of it. You can kind of see. Also, the alt is supposed to be grounded!? The factory one wasnt but my 270 has a much smaller stud on the side plastec part of the alt is that a ground (ohio generator)
You will by far see the best electrical gain by equalizing you grounds to match your power. Grounds are the most under utilized upgrade anyone can do to a system
  • Who's Online   0 Members, 0 Anonymous, 819 Guests (See full list)
