Okay, so I picked up some aluminum yesterday, and I wanna try to make some bus bars for my front batts. My plan is to move my rear batt to the front, and connect the two with bus bars. Then it will be easier to run wire to the rear bank.
My question is, what is best to drill it with? And, what should I use to polish it up? And, did I get the right aluminum? It's 1/4" x 1", is that thick enough?
Thanks fellas
EDIT:
Here are some pics of the finished product.
I'm happy with the way they turned out. Thanks guys!
Edited by Purplehaze
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
yeah mine is 3/8 by 1 1/12 or 2 i cant remember. i use a drill press and you can use any aluminum polish. it will be alot of work though.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Yeah you can use a high or low speed, aluminium (way we spell it here :P) is a soft metal so it doesnt matter,
same with using a lubricant, doesnt really matter since its alu but can give you a better finish on the hole, less wear on drill bits too :good:
But like they said, drill press and clamps pretty much.
i shook this one kids hand and it just folded in mine. long story short i fucked his girlfriendso.. yeah..
You want this to happen to you? Give decent handshakes people.
I was gifted with an innate ability to distribute wholesale ass beatings in a timely and orderly fashion.
Cool, thanks guys!
And what about drill bits? Are there a particular kind of bits I need to use?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
Are you just drilling holes and using bolts to hold a ring terminal on? That's what I have..I get my aluminum from a farm machinery parts house..they have every nut bolt atc..I use 3/8 x11/2..just use steel wool on it they should clean up nice
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Rays right you can clean it up with steel wool and if you really want to hit it with some aluminum polish and a buffer.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   0 Members, 0 Anonymous, 1671 Guests (See full list)
