not every car works well with port behind driver
ive had VERY good luck with subs bottom port up top
and a 1500 per sub..lol...be wayyy careful if you have electrical to support them
what crap are you smoking in db drag subs pass side port driver side is the loudest spl period........
no matter the car
i wouldnt wast my time doing a wall with those subs but that me
he speaks the truth
R.I.P!
(Nov-29-2009)
92 explorer
current build
kicker subs just arent meant for spl, and just are not worth walling considering how hard it is to make a good wall
Unless you're using the solo x subs
They wall fine, just not as well as others is all. Plus 1500 is a bit much for L7's.
Hammerdown... 1%
whats your budget?
R.I.P!
(Nov-29-2009)
92 explorer
current build
Gains are not volume knobs its very possible to get full output with the gain all the way down depends. On your. Input voltage
There are tons of good subs for a wall Fi/aa audio DC audio IA audio DD audio and there are more
  • Who's Online   0 Members, 0 Anonymous, 1154 Guests (See full list)
