hey whats up. summer is coming. spring is here. lets get this system going.
so currently running M1C @ .5 ohm (no problems at all, doesnt get hot), DD C2C (160x2 @ 2 ohms), and JL 400/4 (100x4 @2ohms) using max spec on all amps. so total current draw max is (150A+40A+40A=230A)
i have stock alternator and big 2. engine block to frame, and batter neg to frame. stock battery location is in trunk. so i dont have run from alt to bat pos.
my question is, should i do 2 runs total (one + and one -) from alt to rear bat? or will i need more for power running? i am using KNU OFC 0 gauge. keep in mind there will be large stock battery and an XS D5100 in rear.
currently my voltage drop is from 13.9 down to 12.4 on full tilt. my plan is to also add another battery(d5100 located right noext to stock attery to right in small space. currently i have the beefiest stock battery known to man. idk what it is but it holds its own. mercedes does well. and also stock wiring throughout car is 4 gauge.0102120046a.jpg
BMW M340 xDrive
Best Scores out of a trunk
154+ windows down, 155+ kick
I would deffinately do two runs because the body is pretty thin and the newer the car the more aluminum used in most cased so that adds resistance to your ground circuit. If you've got the extra wire you could do a neg from batt to frame as well just for extra assurance
Edited by jrchevy87
Take a power and a ground run of good 4ga (with stock alt) or 1/0(If you upgrade) straight from the alt to the rear battery.
I would also run a second run from the alt case to the frame in the front.
Then do a solid battery ground in the rear.
-Drew
uhoh_45 said:
what? english please? the car is 1995. and has a steel frame. not a unibody. but im doing 2 runs (one pos and one neg) min, i just want to know if i should do more than just that.
BMW M340 xDrive
id do one positive run, and one negative run from a engine ground. also you could do a extra 1/0 frame ground.
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
-Drew
ok sounds good. thanks.
dont i already have a solid battery ground in rear?
and also when i have XS power bat in rear too i was told to put pos run from alt to stock bat and neg run from alt to XS bat is this true?
BMW M340 xDrive
im going to do the negative run straight form the alt casing. and where is the extra 1/0 frame ground going to and from?
BMW M340 xDrive
Run everything in parallel with a battery ground.
Alt + and - (plus alt - to ground)
to
Bat + and - (+battery - to ground)
to
Bat + and -
to
Amps
Makes sense?
-Drew
what 1995 car has a "steel frame" 99% of all cars n suvs are unibody
to
to
Bat + and -
to
Amps
Makes sense?
-Drew
yep that makes sense. one more thing. should i connect alt to stock bat or XS power bat? does it matter? and should all amps be on xs power battery?
BMW M340 xDrive
  • Who's Online   0 Members, 0 Anonymous, 1615 Guests (See full list)
