focused313 Posted April 14, 2012 Report Posted April 14, 2012 I currently have 1 4ga power wire running to from the battery up front to the back in my uncles car for his bass amp. Roughly 800-900w RMS as currently connected. I'll be adding a second amp soon for the mids/highs. Do I need to make another run of 4ga, or can I safely and correctly use that current wire into a distribution block, that outputs into two 4ga? Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
Amart88 Posted April 14, 2012 Report Posted April 14, 2012 You would be better off having multiple runs instead of that distro block. 4 ga is cutting it close for the wattage and distance you are running it. I would go with multiple runs of 4ga or even better a run of 1/0 into a distribution block into 4 gauge coming out to the amps My 2005 s10 blazer build. 4 zcon 18's walled.
Noobtastic14 Posted April 14, 2012 Report Posted April 14, 2012 With an average sized four channel that wire will be fine as long as it is GOOD 4ga not POS knock off cheap rubber wire. -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
focused313 Posted April 14, 2012 Author Report Posted April 14, 2012 With an average sized four channel that wire will be fine as long as it is GOOD 4ga not POS knock off cheap rubber wire. -Drew the 4ga I have is from KnuKonceptz. I think I'm going to just get another 4ga kit, but go with the cheaper one. Learning Everyday. Pioneer AVH-P4000DVD Alpine SPS-610C BXI-2008D (2) SWR-1242D / Ported
POPLERO Posted April 15, 2012 Report Posted April 15, 2012 I would say keep the 4awg for the mids/highs amp and run 0awg wire for the sub amp, and since mostly likely the amp won't accept that big sized wire, get a 0awg to 4awg reducer.. this will leave room for upgrading in the future and will help for current flow.. jmo. 2008 TBSS Black Granite Alpine CDA-117 Clarion EQS746 AudioQue Supertweets @ dash Alpine DDT-s30 @ b pillars Alpine SPR-60c @ front doors Alpine SPR-60 @ rear doors Alpine PDX-f4 Second Skin DampPro KNUkonceptz Wiring DCpower 270amp alt Optima YT underhood *temp Two15DCxls Hifonics bxi2610 *temp saz4500 and 4 xp3000s coming soon.
Noobtastic14 Posted April 16, 2012 Report Posted April 16, 2012 A good 4ga can move enough current for a 1k sub amp and interiors amp. I know this is a forum of a million runs of 0ga but seriously a good quality 4ga can handle that job. Is 0ga better? yes. is it crucial? no. -Drew I am a United States Military Arts and Crafts Professional. Sand it off, Paint it on. uhoh_45 said: dont be a pussy P give the jeep to drew
