i know that the owners booklet says to ground the dd1 and cc1 to the amp ground. and ive always seen the ground lead attached to the amp. well, the way both of my amps are for the inputs its VERY hard to get the ground lead attached to the amp. will it work if i take the ground lead and attach it to where i grounded the amps to the frame?
Edited by Kdub26
1992 Camry "Stormtrooper"Quantum Audio DVD/USB/AUX 3.5" single din H/UXS D690Cadence 0g wiring and Kicker 4g wiring(2) Selenium 6w4p's(2) Selenium ST200'sKicker 200.4 (mids & highs)(1)Kicker and (2)Stinger RCA'sSecondSkin in trunk and doors12K HIDsMulitcolor Angel EyesSoon to be done:Big 3Mechman H/O Altsubs?amp?
That thing is going to eat people nearby cars, unsecured objects, and small children
Fixed!
wow nice. i wanted nos on my car but the gf said no. i was just gunna do a 50 shot tho haha
Get a new girlfriend.
help me out!!!
Fixed!
You can ground it by the amps chassis (not a good ground though) or directly to the negative ring terminal for your amps ground. I personally took my alligator clip from the dd-1 and cc-1 and put it around the ring terminal on my batteries ground wire. It has no difference in the readings at all as long as the ground is solid and your wires arent going to move around. Having the ground clip or the positive probe on the dd-1 and cc-1 moving will cause the readings to skew due to the friction and resistance presented in the moving connection and will throw off your results.
If its hard to get to your amps ground id suggest doing this CAREFULLY!!!! Take a paperclip or soldered speaker wire and poke that into the little opening where the wire goes into the amps ground terminal, clip your dd-1 or cc-1 to the paper clip and make sure it will not come into contact with your amps positive or remote wires and short out. This will work as well.
Yes..where ever your amps are grounded you can ground there. same ground all around. just make sure its a solid connection
if its so hard to get to how can you tune the amp then..?
its not hard to get to, its just that i cant clip it onto the amp as easily as steve shows in his vids. ive tried serveal ways to try and clip it on, its just that the plastic that goes around the neg input covers almost the whole terminal (not a bad thing) but i just cant clip it onto the actual amp.
Fixed!
You connect it to any ground. Battery terminal, amp terminal, door hinge, etc.
  • Who's Online   0 Members, 0 Anonymous, 562 Guests (See full list)
