SA-12 Box size help
I have everything set up now. All I need is a box. I would prefer prefab just because it would be easier.
I want LOUD. I like SQ but would prefer it to be louder then a sealed box.
So, with this in mind, Should I have a side port, or front port. Also would probably be going for a box around 3.5 cubes and would fire the subs to the rear of the car. They are going in a trunk btw.
Any suggestions are appreciated.
I should probably mention the subs are dual 2ohm and the amp is a hifonics brz2400.1 and will be wired to 2 ohm.
2 - Sundown Audio SA-12 D4 (Box tuned to 34 hrz)
1 - RF t1500.1bdcp
1 - RF t400.4
2 - JL Audio C5 5 1/4 in front doors
2 - JL Audio C5 570 in rear deck
2 - JL Audio ZR100 in front pillars
1 - Kenwood ExCelon HU
If you want a prefab, go down to best buy and pick the one that looks prettiest.
If you want a real box, it's worth the effort
Prefabs are tuned the way they want (usually high) and built poorly in many cases, a rectangular box is easy to build, you can have the parts cut for you in office depot for example, most of the times port/subs in the same face firing backwards or frontwards is used. you will be pushing 850W per sub at 2 ohm which should be fine for them.
  • Who's Online   1 Member, 0 Anonymous, 1697 Guests (See full list)
