Ground to alt bracket question
Well I just ran my 2 1/0 ground runs from my trunk batt to my engine compartment. i will be attaching them onto the alt mounting bolts. Should I put both on one bolt or one on each? and do I need to sand the alt where to bolt goes to bare metal? Thanks
I've never really understood why everyone runs a ground wire to the alt bracket. Wouldn't it be easyier to run it to the engine block? There are extra bolt holes there for a reason.
But to answer your question if the if you car is a unibody then a ground on the same bolt is the same as anywhere. Also if the bracket is painted then yes you need to sand it.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
There arent and accessable unused bolt holes in my engine and the alt bracket is more direct.. i think. I will be grounding to the body in the trunk also but I want as much current flow as I can get.
From my research you should run one to your underhood battery if you have one, and one to your alternator. That's what members have told me atleast.
Optima Redtop Under Hood
Vmax CT800 Outback
Big6?(lol) 0/1 KnuKoncepts
2x 15" RF T1's in 7.7cuft @32hz
Audiopipe aqx3500.1d
Pioneer DEH-5000UB
I was actually just going to post something related to this, I wasn;t sure if Mechman had an anti-corrosion coating on their alternators. I overlooked that when putting it in, and it'd be a pain to take it back out, haha.
  • Who's Online   0 Members, 0 Anonymous, 1221 Guests (See full list)
