Just out of curiosity, ive always wondered when i see a system with an amp mounted to the box itself does the vibration from the subs cause any damage to teh amp at all over time? Im gettign ready to redue my whole system and it would be more space efficient for me to mount my amp to the box but i dont wan tto do anything that is going to potentially damage my amp. Thanks
i have my amps mounted to my box, i havent had any problems with it yet, if you're worried about it just put another piece on the back of the box and screw the amps to the extra piece
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
wrong section to post in but anywho, should be fine to put amps on sub box. If you ask me the box is only vibrating as much as the rest of your car is haha :P
Honda Accord SirT + Mad sounds = Awesomeness
VTEC go BRAAAAAPPPP :P
http://www.stevemeadedesigns.com/board/topic/141261-99-accord-sirt-sq-build/
Alright well i never done the big 3 so i see in my vision my truck on fire...
yes the vibrations from the box can damage the amp some people use rubber spacers to help with the vibrations personally i just try to avoid putting it on the box..also yu posted in the wrong section dont be surprised if it gets deleted
If your box is built solid enough it shouldn't vibrate any more than any other surface you mount to. I've mounted amps to boxes many times and never had an issue but my boxes are usually more solid than anything else in the vehicle.
www.facebook.com/BILLatDivineCreationsPhoto
He was taunting me. He's all like "come at me bro!" So I'm like "I'm coming at you bro!" And he's like "hey, fuck you" *chomp*. Then I killed it. I win.
^^^ you have truly taken being a lazy fuck to a new level tonight, an MRE. WOW
so true and i never had a problem
My build
http://www.stevemead...20#entry2018495
Car: 2003 Cadillac DTS
(1) Hifonics Brutus BRZ2400.1
(1)Hifonics Zrx600.4
(1) 1000 watt crunch amp
(1)200 watt boss amp
(2) Pyramid TW46
(4) Infinity Kappa 60.9cs
(1) EV 10 inch
(2) XSpower 1200
(4) Pyramid TW18
box tuned at 32 Hz
(2) DC level 3
It will be fine if your box is strong, use some rubber washers if you want.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
