PARTING OUT THE DC Audio SUBURBAN!!
Alright guys I'm really going through with it, I'm selling the Burban I have compiled a list of just about everything but I'm sure i have missed something but the list is just for those that do not know the truck or know about it
Suburban
2006 suburban LTZ edition, 6.0L, V8 AWD, 98k miles oil changed every 3,000 miles, always kept up on maint. greasing ball joints and all steering & suspension components etc.
Just bought the 4" lift keys and the rear coil springs are off of a 2011 F350 front suspension and i also added the extra load coilovers and i still have the bags to go inside the coils if you wanted to lift the rear end a few more inches, i also just purchased new 10ply Nitto Terra Grapplers (can support over 13,000lbs) mounted on the 20" SS wheels
The truck is all done right if you wanted to drive it across the country you could.... Really reliable and nice vehicle I just put the rear buckets in it but I also still have the second and third row bench seats if anyone wanted them with it. just went through the whole truck signal wise with knukonceptz rca's and speaker wire which I have extra of and will throw in and also just re did the whole sub wiring with knu 8g inside the box and 4g speaker leads to the amps
The list of goodys:
12- 15" DC XLs
3- DC 9K sub amps
1- American Bass VFL 3500.2FR highs amp
1- Sound Digital SD250.2D highs amp (pocket sized amp)
1- MB Quart onyx 80.4 super tweeter amp
23- XS Power D3400 batteries
400'+ of 2/0 charge lines and grounds (solid copper)
200'+ of tsunami & American bass 1/0 wire from bus bars to amps
2- custom made and engraved bus bars with machine work (hidden set screws) on the top battery bank in the hatch area
8- Crescendo MP8's 8" midrange
2- Crescendo MP6's 6" midrange (also have 2 more 6" not installed)
6- Dayton audio 4" full ranges
4- American Bass SQ-05T super tweeters (also have 4 more not installed yet)
2- 4" Selenium super tweeter horns
2- Selenium ST350 super tweeters
3- Singer Alternator 350amp externally regulated alts on a tejcurrent triple bracket
2- Blue Fin fully adjustable external voltage regulators ran off a stinger solenoid for great power connection (little to no voltage sway bc of the good power and added grounds)
The whole roof has been sheeted inside with 3/16" steel plate and spray foamed between the steel layer an outside roof skin (solid as a rock!)
Also the steel plate roof was drilled and taped for the 2" steel pipe adjustable stripper pole (threaded on both ends 1 being reverse threaded to extend or shorten with a twist of the pole, also the floor was plated under the truck to sandwich the floor pan with the stripper pole to ensure it doesn't rip
The doors have all got multiple layers of second skin damplifier as does the floor from the box forward
Also has 2 red stinger voltage meters to monitor voltage at the sub amps and at the highs amps, the truck also has all the wiring for an outside podium 20' stinger 9conductor wire 2- 20' 4ch stinger RCA's and an extra PAC-LC1 knob to control the sub output the truck comes with an Alpine 305x media head unit with the 3.5" screen
The front doors and A pillars are custom fiberglassed
The doors are wrapped in a color matching leather with carbon fiber inserts around the 4- 8" drivers per door and also the doors house a st350 super tweet, the A pillars house 4- SQ05T 1" super tweeters and 4- 4" Daytons
The box was designed and built by Mike Singer just a little info on the box...
It took over 14 sheets of birch ply
4 gallons of Fiberglas resin
Gallons of wood glue and liquid nails
Hundreds of dollars spent in stainless steel hardware to bolt the 400'+ of steel used to re enforce the shell and baffles, steel includes angle iron, square tubing, round schd 80 pipe, and flat bar... Inside of the ported chamber is color matched to the truck the back wall in the hatch is covered in black suede and has a custom amp rack made of steel like the amps are floating and the front of the box (loading wall) is a custom mixed up color match wood stain and the wood is oak hard ply 4layers thick up front
The truck can do over 160db on less than 18k rms the truck is very musical it has well over a 60hz pass band
A few pictures from SBN
The best way to contact me is through email or text
[email protected]
270-929-9179
Please guys serious offers only I'm selling it for payoff, I will also take a video later today or tomorrow of the truck playing and try to go over everything...
Thanks guys
Blake
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
I will leave the truck for sale for a while maybe 4-5 months and if it doesn't sell then I will be tearing it down to part it out...
Here are some videos of it in action
Please let me know if I need to post some type of identification on the pics but if you look at the pics you can see trulywickedcustoms on my back window
Thanks blake
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
I really need to get $34k that's what I owe on it but that's a little flexible I can give a little
I know that seems like a lot but if you go add up that list iv got over 90k invested in the truck
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Did you set a record for park and pound with this truck? I don't mean to be off topic, just wondering.
Yes I did Steve mick has it now he beat me by .5 db but my truck has a lot left in it as far as park n pound
Thanks
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
How much for shipping? Or would I have to pick it up?
New build coming soon. [center][url="http://imageshack.us/photo/my-images/3/sigtoo.jpg/"][img]http://img3.imageshack.us/img3/9541/sigtoo.jpg[/img][/url][/center]
Depending on where you live I can have it delivered an ill pay half or I can drive it to you
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
Well I'm too busy on my half...But I live in Michigan.
ok you tirekickers. You know the rules. if you are serious about buying thatsw one thing but stop posting just to ask questions.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
